[Mobile 2.9.61] Offline Sync / Downloading over mobile data
2.9.61 mobile sync download offline
  • This topic is locked This topic is locked
1 reply to this topic
#1 ThermoDust OFFLINE
ThermoDust
    Advanced Member
  • Alpha Testers
  • 252 posts
  • Local time: 02:07 PM
  • LocationIllinois, USA
Posted 03 October 2017 - 07:55 PM
Mobile Version: 2.9.61
Android 7.1.2
Logs: https://1drv.ms/f/s!...Xk7TKux_ZDgqlEg
I have noticed once in the past week that the app started to sync in the background while on Mobile data. I checked the settings and for some reason "Sync only on wifi" was unchecked. I enabled that option and went on my way. This morning it was syncing over mobile data again. Once more it was unchecked. Later today, about an hour ago it started to do the same. Maybe this has something to do with me turning on Airplane mode to play it safe while on the train and watching as I don't fully trust offline data.
PS -
Side request. My next step is to clear the storage and start all over, unless otherwise told. Only reason I don't want to do this is then I need to re-pick all the shows and stuff to sync. Maybe have an option to backup the sync choices to the server by user and sub category by device?
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 135027 posts
  • Local time: 03:07 PM
Posted 03 October 2017 - 11:06 PM
Duplicate of: https://emby.media/c...ng-mobile-data/
Also tagged with one or more of these keywords: 2.9.61, mobile, sync, download, offline
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
