wraslor 70 Posted February 27, 2014 Share Posted February 27, 2014 (edited) I'm suddenly seeing super slow performance from the web gui, switching between tv and movie for example will take between 2 and 4 mins when it is usually a couple of seconds for anything to show up. I looked through the log and i'm seeing a lot of warning and debugs like this: Warn - BaseItem: Unable to find linked item at xxxxxxxx I've pulled up several of the items it showing that error for in plex and they play fine, plex is also moving at normal speed. https://app.box.com/s/5gb8we3h9r0izui8zws8 is the log if anyone can take a look and has an idea? Thanks Edited February 27, 2014 by wraslor Link to comment Share on other sites More sharing options...
Luke 37029 Posted February 27, 2014 Share Posted February 27, 2014 are your shortcut files still valid? Link to comment Share on other sites More sharing options...
wraslor 70 Posted February 27, 2014 Author Share Posted February 27, 2014 Shortcut file? Link to comment Share on other sites More sharing options...
Luke 37029 Posted February 27, 2014 Share Posted February 27, 2014 the lnk files in your library Link to comment Share on other sites More sharing options...
wraslor 70 Posted February 27, 2014 Author Share Posted February 27, 2014 (edited) You'll have to help me out here are they created automatically and how do I check them? not sure if it helps but I'm seeing it take my cpu utilization up to 80 % and hold for a while until the web gui starts populating then it drops down to 1-3% Edited February 27, 2014 by wraslor Link to comment Share on other sites More sharing options...
wraslor 70 Posted February 27, 2014 Author Share Posted February 27, 2014 (edited) Well whatever it was, it is fixed by uninstalling and re-installing. EDIT spoke too soon, now that it's all configured it's doing it again. Will continue to investigate. Edited February 27, 2014 by wraslor Link to comment Share on other sites More sharing options...
Solution wraslor 70 Posted February 27, 2014 Author Solution Share Posted February 27, 2014 Ok seem to have figured it out. First I removed all plugins, no change. Next I removed all libraries and added back one by one scanning after each add. Everything was fine until I added back my auto boxset folder then my problem popped back up. Deleted everything in auto boxsets and let the server rebuild them. All is now working. Link to comment Share on other sites More sharing options...
