Clark 0 Posted August 28, 2017 Share Posted August 28, 2017 I've recently been having an issue on the beta app playing streaming videos being transcoded where everytime I push the replay button, there is no audio for 5-10 seconds when the video jumps back. Also, the same time I started having that issue, there are random times when streaming a video where the video will freeze, the audio will repeat the last few seconds and the video smoothly resumes playing when the audio syncs back to the spot of the video freeze. I cannot say exactly when this started, however, it was within the past month, and after a beta app update. I'll try to upload a log file when next I replicate, but feel free to comment in the meanwhile in case it's something you all are aware of and probably working on. Link to comment Share on other sites More sharing options...
ebr 14910 Posted August 28, 2017 Share Posted August 28, 2017 I don't believe there have been any changes in the app that would affect any of this. More than likely, it is related to either firmware on the device (there are known issues with current firmware) or, possibly how the transcodes are happening (if so) on the server. Link to comment Share on other sites More sharing options...
Nisten 15 Posted August 28, 2017 Share Posted August 28, 2017 I've noticed this too on the emby beta app. Not the audio delay issue but the random repeat issue. 1st instance - After about 3 minutes into the tv show, it jumped back to the beginning of the episode 2nd instance - After the episode was supposed to go off and auto-play the next episode, it jumped back to the middle of the episode it just played. Link to comment Share on other sites More sharing options...
Clark 0 Posted August 29, 2017 Author Share Posted August 29, 2017 I've noticed this too on the emby beta app. Not the audio delay issue but the random repeat issue. 1st instance - After about 3 minutes into the tv show, it jumped back to the beginning of the episode 2nd instance - After the episode was supposed to go off and auto-play the next episode, it jumped back to the middle of the episode it just played. I have that issue as well Nisten, but I've narrowed it down to a problem in how Emby handles hardware transcoding in streaming to the Roku. If using only software it works fine for me. By chance do you have hardware transcoding enabled? Link to comment Share on other sites More sharing options...
Luke 37060 Posted August 29, 2017 Share Posted August 29, 2017 Which GPU option do you have enabled? Link to comment Share on other sites More sharing options...
Nisten 15 Posted August 29, 2017 Share Posted August 29, 2017 yeah, current transcoding options I have enabled are below -Hardware encoding -Hardware decoding (HEVC, VC1, and H264) Link to comment Share on other sites More sharing options...
Luke 37060 Posted August 29, 2017 Share Posted August 29, 2017 What encoding option? Link to comment Share on other sites More sharing options...
Nisten 15 Posted August 29, 2017 Share Posted August 29, 2017 (edited) What exactly do you mean by that? there's no additional options for encoding like there is for decoding (at least with my setup anyway) Edited August 29, 2017 by Nisten Link to comment Share on other sites More sharing options...
Luke 37060 Posted August 29, 2017 Share Posted August 29, 2017 What encoder in other words. Link to comment Share on other sites More sharing options...
Nisten 15 Posted August 30, 2017 Share Posted August 30, 2017 Intel QuickSync Link to comment Share on other sites More sharing options...
Luke 37060 Posted August 30, 2017 Share Posted August 30, 2017 Ok yes with the transcoding format we use we've been seeing the quick sync encoder encoding with the wrong timestamps and that is causing this. @@Waldonnis do you know if this is still an issue in newer ffmpeg releases? thanks. Link to comment Share on other sites More sharing options...
Nisten 15 Posted August 30, 2017 Share Posted August 30, 2017 Currently testing the 20170827 ffmpeg build - haven't tried it with the emby beta roku app though Seems to work fine with transcoding dvd size mkv files Link to comment Share on other sites More sharing options...
Waldonnis 148 Posted September 1, 2017 Share Posted September 1, 2017 Ok yes with the transcoding format we use we've been seeing the quick sync encoder encoding with the wrong timestamps and that is causing this. @@Waldonnis do you know if this is still an issue in newer ffmpeg releases? thanks. No idea, unfortunately (first I've heard of it that I can recall). A lot was fixed/changed/added since the 2016 build in libavcodec, at least, so it's worth checking a later build. Link to comment Share on other sites More sharing options...
Clark 0 Posted September 1, 2017 Author Share Posted September 1, 2017 Ok yes with the transcoding format we use we've been seeing the quick sync encoder encoding with the wrong timestamps and that is causing this. @@Waldonnis do you know if this is still an issue in newer ffmpeg releases? thanks. That's the first I've heard a confirmation to this too, although I've suspected as much. Over the past few months I tried over a dozen different builds of ffmpeg from before and after the default included with Emby. None made any difference. If anyone can point me to a download or compile a custom version for me to try, I'm willing to test to try to get it working. I built my server around hardware transcoding and cant use it Link to comment Share on other sites More sharing options...
Nisten 15 Posted September 5, 2017 Share Posted September 5, 2017 I would also like to know if there's a recommended alternate ffmpeg build or process other than the default. Link to comment Share on other sites More sharing options...
Luke 37060 Posted September 5, 2017 Share Posted September 5, 2017 You could try something more recent. Link to comment Share on other sites More sharing options...
vaise 304 Posted September 5, 2017 Share Posted September 5, 2017 Iv noticed a niggly thing along the same lines, not enough for me to worry too much. It started about 2 weeks ago - around the time of roku update - so it could be emby server, roku firmware, nextPVR version or Roku beta app - too many unknowns and it is not a big issue so iv not put the effort into solving/reporting it to date. Issue is, if you are wathcing a recorded a TV show, and it overruns (as they all do here in Aus so we pad for 15 minutes), then at about the time the show should end, we get the screen freeze but the sound continue. I just click the right arrow on the roku and it fixes itself. All the house know to do that now and no complaints. I have a theory that this is to do with the next recording starting up on the same tuner' i.e recording on channel 10 starts at 8:30, then at 9:30 we get the freeze - which is the time that another recording starts on the same channel. As I said, its no biggie as you quickly press right arrow and all is well - but this def did not happen older than 2 weeks ago. Link to comment Share on other sites More sharing options...
Nisten 15 Posted September 6, 2017 Share Posted September 6, 2017 You could try something more recent. Changed to 9/4 ffmpeg build - Will try to test tonight or the next time I get a chance. Also does it matter which "linking" we have the build set to for the dlls & exes? I've been using static linking but there's a shared linking option Link to comment Share on other sites More sharing options...
Luke 37060 Posted September 6, 2017 Share Posted September 6, 2017 static is all we test with. Link to comment Share on other sites More sharing options...
dcook 265 Posted September 6, 2017 Share Posted September 6, 2017 I have seen the random repeat issue as well a few times. Usually its just 1 second or 2 that repeats, but it does seem to be random. Link to comment Share on other sites More sharing options...
Nisten 15 Posted September 7, 2017 Share Posted September 7, 2017 Changed to 9/4 ffmpeg build - Will try to test tonight or the next time I get a chance. Also does it matter which "linking" we have the build set to for the dlls & exes? I've been using static linking but there's a shared linking option Tested w/ the 9/4 build, still an issue. I was trying to watch a movie and 20 minutes in, it jumped 10 minutes back (reproduced on regular emby app & emby beta app) Link to comment Share on other sites More sharing options...
ebr 14910 Posted September 7, 2017 Share Posted September 7, 2017 This is still with QuickSync enabled and it goes away with it disabled? Link to comment Share on other sites More sharing options...
Nisten 15 Posted September 7, 2017 Share Posted September 7, 2017 This is still with QuickSync enabled and it goes away with it disabled? Didn't have this issue prior to enabling Quick Sync so I'm assuming yes - I'll turn off QuickSync later today in order to verify Link to comment Share on other sites More sharing options...
Nisten 15 Posted September 8, 2017 Share Posted September 8, 2017 (edited) So far the issue doesn't appear to be occurring anymore once QuickSync was disabled Edited September 8, 2017 by Nisten 1 Link to comment Share on other sites More sharing options...
Luke 37060 Posted September 8, 2017 Share Posted September 8, 2017 Thanks for the feedback. Link to comment Share on other sites More sharing options...
