Luke 37055 Posted January 8, 2018 Share Posted January 8, 2018 i wonder if we could feed mpv the video_ts folder instead. Link to comment Share on other sites More sharing options...
Guest asrequested Posted January 8, 2018 Share Posted January 8, 2018 (edited) i wonder if we could feed mpv the video_ts folder instead. That's what I was thinking. But I have an update. The lack of audio is a general playback glitch. It does it, regardless. If you manually change track during playback, the audio then plays. And everything else plays, correctly. That is to say that the trailer plays, then the movie plays directly after it. I am testing with the test build, I may add. I'll run it with the release, and see what happens. UPDATE: Without the trailers folder It does play, but it takes a minute to start. In the test build, it starts almost instantly. With the trailers folder there, well, the circle is still spinning...wait...it finally started. So, a couple of things. 1. It takes a long time to start 2. The trailer doesn't play, it goes to the movie 3. The audio plays, correctly Edited January 8, 2018 by Doofus Link to comment Share on other sites More sharing options...
Abobader 2942 Posted January 8, 2018 Share Posted January 8, 2018 Good day, I always delete the "AUDIO_TS" folder, many times it case problem with some players. My best Link to comment Share on other sites More sharing options...
Mopar_Mudder 14 Posted January 9, 2018 Share Posted January 9, 2018 (edited) i wonder if mpv gets confused by the contents due to the backups and trailers folders, and then as a result doesn't know how to play it. I got rid of the Trailer and Backdrop folders then re scanned the library. It did actually play this time but it was just a spinning circle for 2 minutes before it started. Other thing I see is that the Dash Board says it is transcoding, and I wouldn't think it should be. Edited January 9, 2018 by Mopar_Mudder Link to comment Share on other sites More sharing options...
Guest asrequested Posted January 9, 2018 Share Posted January 9, 2018 It probably doesn't have direct access, so it needs to transcode. That's why I asked if you used the network location. Link to comment Share on other sites More sharing options...
Mopar_Mudder 14 Posted January 9, 2018 Share Posted January 9, 2018 It probably doesn't have direct access, so it needs to transcode. That's why I asked if you used the network location. Not sure what you mean by network location, but BluRay plays fine and does not transcode. Link to comment Share on other sites More sharing options...
Guest asrequested Posted January 9, 2018 Share Posted January 9, 2018 In your library settings, do you have the shared network folder, filled in? Link to comment Share on other sites More sharing options...
Mopar_Mudder 14 Posted January 9, 2018 Share Posted January 9, 2018 Is this what you are talking about. I guess I don't understand how else you would get movies to show up in the library, if it wasn't filled in you would not have a library? Link to comment Share on other sites More sharing options...
Guest asrequested Posted January 9, 2018 Share Posted January 9, 2018 (edited) Ok, so you used the network folder. That's good. Can you post the transcode log? Also, you can try the test build, and see what results you get. If you go to the first post in this thread, you can download it https://emby.media/community/index.php?/topic/46763-theater-mpv-test/page-133&do=findComment&comment=529438 Edited January 9, 2018 by Doofus Link to comment Share on other sites More sharing options...
Luke 37055 Posted January 9, 2018 Share Posted January 9, 2018 If it transcodes then it's only expiremental, so you want to configure library setup to avoid transcoding at all. @ didn't we at some point see something about dvd deprecated in mpv? in which case an external player would be needed now if that's true. Link to comment Share on other sites More sharing options...
Mopar_Mudder 14 Posted January 9, 2018 Share Posted January 9, 2018 Ok, so you used the network folder. That's good. Can you post the transcode log? Also, you can try the test build, and see what results you get. If you go to the first post in this thread, you can download it https://emby.media/community/index.php?/topic/46763-theater-mpv-test/page-133&do=findComment&comment=529438 Here is the transcode log, not sure when I can get at trying the test build. Trans Log.txt Link to comment Share on other sites More sharing options...
Luke 37055 Posted January 9, 2018 Share Posted January 9, 2018 Ok but this is an mpg file, this isn't a dvd folder rip. Are we talking about the same thing here? Link to comment Share on other sites More sharing options...
Mopar_Mudder 14 Posted January 9, 2018 Share Posted January 9, 2018 Ok but this is an mpg file, this isn't a dvd folder rip. Are we talking about the same thing here? Sorry that was the wrong log, forgot I played something after that. This should be the right one. Trans Log.txt Link to comment Share on other sites More sharing options...
Luke 37055 Posted January 9, 2018 Share Posted January 9, 2018 ok, based on this log it looks like the player may have had an error when first trying to direct play, and then as a result it automatically switched to transcoding. We may need to verify that mpv still actually supports dvd folder rips, and if not, then an external player will be needed. Thanks. Link to comment Share on other sites More sharing options...
Mopar_Mudder 14 Posted January 9, 2018 Share Posted January 9, 2018 Ok, let me know what you find out. Or better yet tell me how to batch convert all my DVD folder rips, LOL. Link to comment Share on other sites More sharing options...
Guest asrequested Posted January 9, 2018 Share Posted January 9, 2018 They play very well (apart from the audio glitch) in the test build. I don't recall DVD being depricated. I'll take a look, later. Link to comment Share on other sites More sharing options...
Guest asrequested Posted January 9, 2018 Share Posted January 9, 2018 A quick look in the manual for DVD playback, and it appears to be still supported Link to comment Share on other sites More sharing options...
Luke 37055 Posted January 10, 2018 Share Posted January 10, 2018 Thanks @. Actually if i had to guess, I bet theater doesn't have access to those network folders therefore it's unable to direct play. Link to comment Share on other sites More sharing options...
rbknox 4 Posted March 3, 2021 Share Posted March 3, 2021 So this topic kind of just ended. Why were the ripped DVDs not playing? Was this ever resolved? I just setup Emby. I have WMC movies, some Blu-ray rips and some DVD rips. They're all in folders on one share. I setup a Movies library. I have Emby Theater on Windows 10. I can play Blu-rays and WMC files no problem. But DVDs just sit there with the big circle in the middle of the screen. When I try to play the DVDs from the Server Web app, they play fine. I do not believe I have any share permission problems - all under same user id. Plus all movie types all under same share. I have used \\Server\folder convention and added the same in optional Share folder entry. It seems I have the same problem as being discussed here ... Link to comment Share on other sites More sharing options...
Luke 37055 Posted March 3, 2021 Share Posted March 3, 2021 7 hours ago, rbknox said: So this topic kind of just ended. Why were the ripped DVDs not playing? Was this ever resolved? I just setup Emby. I have WMC movies, some Blu-ray rips and some DVD rips. They're all in folders on one share. I setup a Movies library. I have Emby Theater on Windows 10. I can play Blu-rays and WMC files no problem. But DVDs just sit there with the big circle in the middle of the screen. When I try to play the DVDs from the Server Web app, they play fine. I do not believe I have any share permission problems - all under same user id. Plus all movie types all under same share. I have used \\Server\folder convention and added the same in optional Share folder entry. It seems I have the same problem as being discussed here ... Hi, you may want to setup an external player for dvd folders. Link to comment Share on other sites More sharing options...
