Luke 36876 Posted July 31, 2018 Share Posted July 31, 2018 Thanks for the info. Link to comment Share on other sites More sharing options...
Ice 14 Posted December 31, 2018 Share Posted December 31, 2018 I'm having the same problem, it use to work then it stopped working so I stopped using it, I wasn't connecting remotely much anyway. My phone provider just 3x my data allowance so I thought I would try getting it going again. Emby is not reporting the correct WAN address (but use to), if I put the correct WAN address in it still doesn't connect. I can still connect using emby connect via my pc but I presume that is just using my local ip. Locally it is working just fine no problems at all Emby Server: 3.5.3.0 Win 7 Ultimate 64bit Intel i7-7700 32GB Ram Link to comment Share on other sites More sharing options...
Solution Ice 14 Posted December 31, 2018 Solution Share Posted December 31, 2018 Fixed my problem, at some stage I must of removed the tick from "Allow remote connections to this Emby Server." found in the advanced user section which has also fixed up the remote WAN port ip address as well. I probably did that when I was receiving a lot of requests from people I don't know to access my Server....:/ 1 Link to comment Share on other sites More sharing options...
Luke 36876 Posted January 1, 2019 Share Posted January 1, 2019 Thanks for the feedback ! Link to comment Share on other sites More sharing options...
