kugelzucker 1 Posted April 14, 2017 Share Posted April 14, 2017 (edited) hi all, hope this is the right place. i am running emby-server-3.2.10.0 (doesnt matter, happened on more than one version) using pkg on a freenas-9.10 server. i noticed that when i set a password for a user using the webinterface i get access to another field for local network login offering easy-pin-access stuff. nice. if i check the box for that it works as intended. if i disable the password for the user again by updating it to an empty one the field for local pin access goes away but is still active. meaning that i still see a little lock symbol next to the user on my fire-tv and need to enter the easy-access-pin to login. since i disabled the password i'd expected that all login restrictions would be gone now. if you feel like this is a valid point please look into that. thanks for making a great tool & product! edit: solved Edited April 14, 2017 by jsteidl Link to comment Share on other sites More sharing options...
Luke 36876 Posted April 14, 2017 Share Posted April 14, 2017 Hi, this is resolved in 3.2.12. thanks ! Link to comment Share on other sites More sharing options...
kugelzucker 1 Posted April 14, 2017 Author Share Posted April 14, 2017 (edited) damned, i knew i shouldve updated from .10 first and then write this post. thanks! lucky me seeing this in three subsequent versions and when i finally decide to do something about it ... edit: freebsd-ports and pkg not holding it yet, but thanks for fixing it! Edited April 14, 2017 by jsteidl Link to comment Share on other sites More sharing options...
Luke 36876 Posted April 14, 2017 Share Posted April 14, 2017 Thanks for reporting back. Link to comment Share on other sites More sharing options...
