Fresh Install Krypton 17.1-RC1 Raspberry Pi2 Crashing
tman12
 Share
tman12
Hello,
I'm using the latest OSMC for Raspberry Pi2 with the Emby for Kodi addon and when the library is scanning it just suddenly crashes and I see the sad face screen before starting all over again. Everything was working perfect before I update OSMC. I figured it might be an issue with the update so I did a fresh install and I'm still getting the same problems. The steps I followed were to download the img from OSMC, write to micro SD using WIn32 Disk Imager, install Emby for Kodi via file manager using Beta 1.0.5, login to my Emby Server via the addon, begin library update. This is the same process I followed before so I don't think there is any issue with how I'm executing everything. I have added a URL to the log file (and attached.txt) so hopefully someone can take a look and let me know if anything stands out.
Kodi OS: OSMC latest version OSMC_TGT_rbp2_20170210
Emby Server: Version 3.2.7.0
Emby for Kodi: 1.0.5 repository
Scan gets about 20-30% in for Movies and then crashes to sad face screen, process repeats itself every time.
Log File: http://paste.osmc.io/inojukafey
Any help is greatly appreciated!
Thanks,
Tman12
Kodi Log.txt
Edited by tman12
Link to comment
Share on other sites
tman12
Well I figured out a workaround to this issue, you have to lower the cached artwork down to 15 in order for Emby for Kodi to work on 17 with Raspberry Pi2. If that still doesn't work, try just completely turning off the feature altogether.
Link to comment
 Share
