hjason7812 25 Posted February 4, 2017 Share Posted February 4, 2017 Hello my server was working just fine and then it stopped getting information and adding thumnails to the videos.. What is going on?! and please fix it Link to comment Share on other sites More sharing options...
Luke 37059 Posted February 4, 2017 Share Posted February 4, 2017 hi @@hjason7812 can you please discuss the problem in more detail? Thanks ! Link to comment Share on other sites More sharing options...
hjason7812 25 Posted February 4, 2017 Author Share Posted February 4, 2017 nothing else to say its not getting the information or pictures for the videos anymore since i update to the new version.3.1.5 or something like that Link to comment Share on other sites More sharing options...
Luke 37059 Posted February 4, 2017 Share Posted February 4, 2017 if you click on the library in question in Emby library setup, are the various metadata settings set the way you want them? thanks. Link to comment Share on other sites More sharing options...
Happy2Play 8281 Posted February 4, 2017 Share Posted February 4, 2017 What does your log say? Link to comment Share on other sites More sharing options...
hjason7812 25 Posted February 5, 2017 Author Share Posted February 5, 2017 the log doesn't say anything.. and the metadata settings are defult Link to comment Share on other sites More sharing options...
Happy2Play 8281 Posted February 5, 2017 Share Posted February 5, 2017 What about your per Library setting? Dashboard-Library-select each library Link to comment Share on other sites More sharing options...
Luke 37059 Posted February 5, 2017 Share Posted February 5, 2017 can you show a screenshot of the metadata settings? thanks ! Link to comment Share on other sites More sharing options...
imadunatic 28 Posted February 7, 2017 Share Posted February 7, 2017 Well I'll bite, it appears the last time mine created a thumbnail or an NFO was January 27. I thought it was just me, but it's starting to cause some weird issues with sync on my kodi installs (syncs the content fine, but then says it can't find it when attempting to play. Should I start a new post or join in here? It's the exact same issue. Permissions are fine, I can't seem to locate the path substitution stuff anymore (did it move?). Link to comment Share on other sites More sharing options...
imadunatic 28 Posted February 7, 2017 Share Posted February 7, 2017 Digging into the logs, these errors repeat over and over and over for multiple providers, this just happened to be thetvdb, but I see the errors for omdb, open movie database, basically all scrapers are failing at every library sync. I can send full logs, but I'd rather not post them here unless you tell me they're sterile. Emby Error.txt Link to comment Share on other sites More sharing options...
Happy2Play 8281 Posted February 7, 2017 Share Posted February 7, 2017 (edited) Without a full log no one can tell what information you are trying to get from TVDB and OMDB is having issues as stated on their homepage. Your log snippet posted basically says can't get info without seriesid. I can't seem to locate the path substitution stuff anymore (did it move?). This was relocate to each library along with some settings. Dashboard-Library select a library to see option and select already linked folder to see optional network path. Edited February 7, 2017 by Happy2Play Link to comment Share on other sites More sharing options...
imadunatic 28 Posted February 7, 2017 Share Posted February 7, 2017 Without a full log no one can tell what information you are trying to get from TVDB and OMDB is having issues as stated on their homepage. Your log snippet posted basically says can't get info without seriesid. This was relocate to each library along with some settings. Dashboard-Library select a library to see option and select already linked folder to see optional network path. Are the logs safe to post in full? Link to comment Share on other sites More sharing options...
imadunatic 28 Posted February 7, 2017 Share Posted February 7, 2017 This was relocate to each library along with some settings. Dashboard-Library select a library to see option and select already linked folder to see optional network path. So I need to select each folder in each library and enter a path substitution? The only place I'm seeing the option is after I select a library, then select a folder in that library, then I get this: Link to comment Share on other sites More sharing options...
Happy2Play 8281 Posted February 7, 2017 Share Posted February 7, 2017 You could sanitize personal info or PM them to Luke referencing this topic. You have verified since the setting "Save artwork and metadata into media folders" has moved it is still enabled per library, correct? Link to comment Share on other sites More sharing options...
Happy2Play 8281 Posted February 7, 2017 Share Posted February 7, 2017 So I need to select each folder in each library and enter a path substitution? The only place I'm seeing the option is after I select a library, then select a folder in that library, then I get this: Correct example Link to comment Share on other sites More sharing options...
imadunatic 28 Posted February 7, 2017 Share Posted February 7, 2017 You could sanitize personal info or PM them to Luke referencing this topic. You have verified since the setting "Save artwork and metadata into media folders" has moved it is still enabled per library, correct? Just found that option under each library and it's not checked. Did this happen to change during the 3.1.5.0 update? It appears that is when mine started flaking out, looks like maybe the setting just didn't carry over for whatever reason. Also, I don't have any path substitutions saved in each library, I'm guessing this is causing some of the heartburn as well. Do I have to set a separate path substitution for each folder in each library or am I missing the "substitute all" like was in previous server versions? Link to comment Share on other sites More sharing options...
Happy2Play 8281 Posted February 7, 2017 Share Posted February 7, 2017 Do I have to set a separate path substitution for each folder in each library or am I missing the "substitute all" like was in previous server versions? This is per library setting now. As for the "Save artwork and metadata into media folders" setting I believe it got moved in version 3.1. Link to comment Share on other sites More sharing options...
imadunatic 28 Posted February 7, 2017 Share Posted February 7, 2017 Thanks Happy. I'm not gonna lie, this thing has been on cruise control for many versions. I'll go update for the new settings and see how it sorts out. My gut feeling is I'm having 2 issues, one is the not saving metadata in media folders, second is all of my path substitutions didn't transfer. Link to comment Share on other sites More sharing options...
Happy2Play 8281 Posted February 7, 2017 Share Posted February 7, 2017 @@Luke Unless it was fully removed Path substitution should still exit in you system.xml. I just made the changes when they were updated awhile ago. 1 Link to comment Share on other sites More sharing options...
imadunatic 28 Posted February 7, 2017 Share Posted February 7, 2017 Previously, I only had my parent folders substituted, as opposed to each individual folder (I have movies split by MPAA rating, I only had the G://Movies folder substituted to \\SERVER\Movies, not the G://Movies/PG-13 folder. I'm thinking this may be why nothing transferred). Everything is updated now, just need to update my kodi databases and see if all is well. Link to comment Share on other sites More sharing options...
imadunatic 28 Posted February 7, 2017 Share Posted February 7, 2017 All is well, in summation: Network paths were not set for each individual folder due to being able to set network paths for higher level folders previously The options for "save metadata and artwork into folders" did not carry over during a server update either. Checking this option for each library, then refreshing fixed my missing metadata. Link to comment Share on other sites More sharing options...
Luke 37059 Posted February 7, 2017 Share Posted February 7, 2017 @@imadunatic thanks for reporting back ! Link to comment Share on other sites More sharing options...
