Wayve 0 Posted January 8, 2017 Share Posted January 8, 2017 Dears, 1stly, my wishes to all for a shiny 2017!!! I would like to express my appreciation for the valuable efforts & support within this Emby "Technosystem"! Now that Subtitles and Resume functionalities are fully working on Samsung Smart TVs via DLNA, I would appreciate considering support for Direct Play of LiveTV content to DLNA smart TVs. In my case, the Live TV content is an M3U list of HTTP-based mpeg-ts streams (.TS), which is currently direct-played to DLNA TV through XUPNPD DLNA media server. Having the same level of functionality through Emby Media server will be a great addition. More specifically, no probing of streams is necessary and no attributes (size, audio channels, duration,...) are needed in describing those streams when browsing the M3U list through the DLNA TV. Below is the DLNA Browse response from XUPNPD to TV: <res size="0" protocolInfo="http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01700000000000000000000000000000">http://url:4044/proxy/0_1_2_23.mpeg_ts</res> Based on the above, keeping the original URL for the individual live streams (assuming mpeg-ts) should be fine for Samsung Smart TV DLNA. What I have noticed so far is that any attempt to stream a transcoded live tv channel from Emby to Smart TV (via DLNA) is failing due to the significant delay (over 15 seconds) resulting from probing/transcoding. Thank you for your support, Wayve Link to comment Share on other sites More sharing options...
Luke 37008 Posted January 8, 2017 Share Posted January 8, 2017 Thanks for the report. Link to comment Share on other sites More sharing options...
