Danee 57 Posted January 19, 2014 Share Posted January 19, 2014 Hello, I run into a problem when I try to play a Live TV show and this one seems to be limited to shows that don't have an English audio track. If I start such a show the created ts stream file is always 32 Kb and seems to contain nothing. The wtv file can be played and contains both audio and video. See the attached partial log. log dut.txt The MBS version is: 3.0.5131.18923, the MBS plugin version is: 1.0.0.14 The ServerWMC version is: 1.0.0.21, build: 1114 Link to comment Share on other sites More sharing options...
Solution krustyreturns 191 Posted January 19, 2014 Solution Share Posted January 19, 2014 Hi Danee, This appears to due to a completeness check we put into the newest version of serverwmc on audio streams. Xmbc'ers are having problems with it too. I updated serverwmc to remove the check (1115), see if that fixes the problem. 2 Link to comment Share on other sites More sharing options...
Danee 57 Posted January 19, 2014 Author Share Posted January 19, 2014 Hi Danee, This appears to due to a completeness check we put into the newest version of serverwmc on audio streams. Xmbc'ers are having problems with it too. I updated serverwmc to remove the check (1115), see if that fixes the problem. Thank you very much! The new build fixed this. I did however need to redo my tv setup in Media Center, is that expected? (I got the infamous "Files needed to display video are not installed or are not working correctly. Restart Media center or computer" Error) Link to comment Share on other sites More sharing options...
