Fixed
Something glitchy with guide information ending up on recordings
guide old data recordings Meet the Press
  • Please log in to reply
8 replies to this topic
#1 FordGT90Concept OFFLINE
FordGT90Concept
    Advanced Member
  • Members
  • 703 posts
  • Local time: 09:20 AM
Posted 19 September 2016 - 03:00 PM
I've recorded Meet the Press for months now and every time it does, the guide information is correct when I look at the guide but the recordings are always dated 2014 which was before I even had Emby. That said, I have probably been recording it since 2014 using MediaPortal and, at one point, I did use MediaPortal plugin in Emby to pull over access from the internal turner. MediaPortal is no longer installed but the issue still persists. As far as I can tell, only Meet the Press has this issue.
Here's the server logs from when the recording occurred:
2016-09-18 08:00:00.0195 Info App: Recording timer fired.
2016-09-18 08:00:00.0351 Info App: Streaming Channel hdhr_4.1_4f9861d46ad3534ae15ba7cb87458be7
2016-09-18 08:00:00.0507 Info HttpClient: HttpClientManager GET: http://192.168.0.43/lineup.json
2016-09-18 08:00:00.0663 Info App: GetChannelStream: channel id: hdhr_4.1_4f9861d46ad3534ae15ba7cb87458be7. stream id:
2016-09-18 08:00:00.3163 Info App: Beginning recording. Will record for 59.9947268183333 minutes.
2016-09-18 08:00:00.3163 Info App: Writing file to path: E:\Series\Meet the Press\Meet the Press 2016-09-18.ts
2016-09-18 08:00:00.3163 Info App: Opening recording stream from tuner provider
2016-09-18 08:00:00.3320 Info HttpClient: HttpClientManager GET: http://192.168.0.43:5004/auto/v4.1?duration=3600
2016-09-18 08:00:00.5663 Info App: Opened recording stream from tuner provider
2016-09-18 08:00:00.5663 Info App: Copying recording stream to file E:\Series\Meet the Press\Meet the Press 2016-09-18.ts
2016-09-18 09:00:00.5677 Info App: Recording completed to file E:\Series\Meet the Press\Meet the Press 2016-09-18.ts
2016-09-18 09:00:00.5677 Info App: Recording completed: E:\Series\Meet the Press\Meet the Press 2016-09-18.ts
2016-09-18 09:01:45.6445 Info LibraryMonitor: E:\Series\Meet the Press\Meet the Press 2016-09-18.ts reports change.
2016-09-18 09:01:45.6445 Info LibraryMonitor: Series (E:\Series) will be refreshed.
2016-09-18 09:01:48.4101 Info HttpClient: HttpClientManager GET: https://www.omdbapi.com/?plot=full&r=json&t=Meet+the+Press&type=movie
2016-09-18 09:01:48.6289 Info HttpClient: HttpClientManager GET: https://www.omdbapi.com/?i=tt4335732&tomatoes=true
2016-09-18 09:01:48.6914 Info HttpClient: Checking for cache file C:\Users\Lee\AppData\Roaming\Emby-Server\cache\httpclient\c95114907c174eb78e9f8ed9e31e9342
2016-09-18 09:01:48.6914 Info HttpClient: HttpClientManager GET: https://api.themoviedb.org/3/movie/tt4335732?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2016-09-18 09:01:49.2382 Error HttpClient: Error getting response from https://api.themoviedb.org/3/movie/tt4335732?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
	*** Error Report ***
	Version: 3.0.6400.0
	Command line: C:\Users\Lee\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe -service
	Operating system: Microsoft Windows NT 6.2.9200.0
	Processor count: 8
	64-Bit OS: True
	64-Bit Process: True
	Program data path: C:\Users\Lee\AppData\Roaming\Emby-Server
	Application Path: C:\Users\Lee\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe
	One or more errors occurred.
	System.AggregateException
	   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
	   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
	   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
	   at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1d.MoveNext()
	InnerException: System.Net.WebException
	The remote server returned an error: (404) Not Found.
	   at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
	   at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)
2016-09-18 09:01:49.2382 Info HttpClient: Checking for cache file C:\Users\Lee\AppData\Roaming\Emby-Server\cache\httpclient\2abeeaad27d9471fd8e4016154359d7c
2016-09-18 09:01:49.2382 Info HttpClient: HttpClientManager GET: https://api.themoviedb.org/3/movie/tt4335732?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers
2016-09-18 09:01:49.3789 Error HttpClient: Error getting response from https://api.themoviedb.org/3/movie/tt4335732?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers
	Version: 3.0.6400.0
	Processor count: 8
	64-Bit OS: True
2016-09-18 09:02:45.6594 Info LibraryMonitor: E:\Series reports change.
2016-09-18 09:02:45.6594 Info LibraryMonitor: E:\Series\Meet the Press reports change.
2016-09-18 09:02:45.6594 Info LibraryMonitor: Series (E:\Series) will be refreshed.
2016-09-18 09:02:45.9407 Info LibraryMonitor: Series (E:\Series) will be refreshed.
Edited by FordGT90Concept, 02 October 2016 - 12:03 PM.
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149030 posts
  • Local time: 10:20 AM
Posted 19 September 2016 - 03:17 PM
Thanks. It's being looked into.
#3 FordGT90Concept OFFLINE
FordGT90Concept
    Advanced Member
  • Members
  • 703 posts
Posted 26 September 2016 - 09:02 AM
Another week and it still has 2014 data.
2016-09-25 08:00:00.0592 Info App: Recording timer fired.
2016-09-25 08:00:00.0592 Info App: Streaming Channel hdhr_4.1_4f9861d46ad3534ae15ba7cb87458be7
2016-09-25 08:00:00.0592 Info HttpClient: HttpClientManager GET: http://192.168.0.43/lineup.json
2016-09-25 08:00:00.0748 Info App: GetChannelStream: channel id: hdhr_4.1_4f9861d46ad3534ae15ba7cb87458be7. stream id:
2016-09-25 08:00:00.0904 Info App: Beginning recording. Will record for 59.998752735 minutes.
2016-09-25 08:00:00.0904 Info App: Writing file to path: E:\Series\Meet the Press\Meet the Press 2016-09-25.ts
2016-09-25 08:00:00.0904 Info App: Opening recording stream from tuner provider
2016-09-25 08:00:00.0904 Info HttpClient: HttpClientManager GET: http://192.168.0.43:5004/auto/v4.1?duration=3600
2016-09-25 08:00:00.3717 Info App: Opened recording stream from tuner provider
2016-09-25 08:00:00.3717 Info App: Copying recording stream to file E:\Series\Meet the Press\Meet the Press 2016-09-25.ts
2016-09-25 08:03:03.4018 Info HttpClient: HttpClientManager GET: http://bot.whatismyipaddress.com
2016-09-25 08:03:03.8393 Info HttpClient: HttpClientManager POST: https://connect.emby.media/service/Servers?id=2044ba3f927436b0fa4f05267f83af15
2016-09-25 08:03:04.0424 Info HttpClient: HttpClientManager GET: https://connect.emby.media/service/ServerAuthorizations?serverId=2044ba3f927436b0fa4f05267f83af15
2016-09-25 09:00:00.3547 Info App: Recording completed to file E:\Series\Meet the Press\Meet the Press 2016-09-25.ts
2016-09-25 09:00:00.3547 Info App: Recording completed: E:\Series\Meet the Press\Meet the Press 2016-09-25.ts
2016-09-25 09:01:45.3853 Info LibraryMonitor: E:\Series\Meet the Press\Meet the Press 2016-09-25.ts reports change.
2016-09-25 09:01:45.3853 Info LibraryMonitor: Series (E:\Series) will be refreshed.
2016-09-25 09:01:53.4477 Info HttpClient: HttpClientManager GET: https://www.omdbapi.com/?plot=full&r=json&t=Meet+the+Press&type=movie
2016-09-25 09:01:53.9165 Info HttpClient: HttpClientManager GET: https://www.omdbapi.com/?i=tt4335732&tomatoes=true
2016-09-25 09:02:03.3383 Info HttpClient: Checking for cache file C:\Users\Lee\AppData\Roaming\Emby-Server\cache\httpclient\c95114907c174eb78e9f8ed9e31e9342
2016-09-25 09:02:03.3383 Info HttpClient: HttpClientManager GET: https://api.themoviedb.org/3/movie/tt4335732?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2016-09-25 09:02:03.7445 Error HttpClient: Error getting response from https://api.themoviedb.org/3/movie/tt4335732?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
	Version: 3.0.7200.0
	Processor count: 8
	64-Bit OS: True
2016-09-25 09:02:03.7445 Info HttpClient: Checking for cache file C:\Users\Lee\AppData\Roaming\Emby-Server\cache\httpclient\2abeeaad27d9471fd8e4016154359d7c
2016-09-25 09:02:03.7602 Info HttpClient: HttpClientManager GET: https://api.themoviedb.org/3/movie/tt4335732?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers
2016-09-25 09:02:03.8852 Error HttpClient: Error getting response from https://api.themoviedb.org/3/movie/tt4335732?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers
	Version: 3.0.7200.0
	Processor count: 8
	64-Bit OS: True
2016-09-25 09:02:45.4318 Info LibraryMonitor: E:\Series reports change.
2016-09-25 09:02:45.4318 Info LibraryMonitor: E:\Series\Meet the Press reports change.
2016-09-25 09:02:45.4318 Info LibraryMonitor: Series (E:\Series) will be refreshed.
2016-09-25 09:02:49.1349 Info LibraryMonitor: Series (E:\Series) will be refreshed.
2016-09-25 09:03:03.4317 Info HttpClient: HttpClientManager GET: http://bot.whatismyipaddress.com
2016-09-25 09:03:03.9160 Info HttpClient: HttpClientManager POST: https://connect.emby.media/service/Servers?id=2044ba3f927436b0fa4f05267f83af15
2016-09-25 09:03:04.1348 Info HttpClient: HttpClientManager GET: https://connect.emby.media/service/ServerAuthorizations?serverId=2044ba3f927436b0fa4f05267f83af15
#4 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149030 posts
Posted 26 September 2016 - 02:10 PM
I don't quite understand. What has 2014 data?
#5 FordGT90Concept OFFLINE
FordGT90Concept
    Advanced Member
  • Members
  • 703 posts
Posted 26 September 2016 - 02:30 PM
The information associated with Meet the Press. The guide, prior to recording, is correct but when I go to look at it after it has been recorded, it claims every time it records it is the same episode in the same season, on the same date in 2014. Because of that, it always marks it as watched even though it is new.
#6 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149030 posts
Posted 26 September 2016 - 02:34 PM
Ok there are improvements for this for the next release. In the meantime I would make sure to be running the latest version of Emby Server.
  • FordGT90Concept likes this
#7 FordGT90Concept OFFLINE
FordGT90Concept
    Advanced Member
  • Members
  • 703 posts
Posted 26 September 2016 - 03:18 PM
Beta or stable? Running stable right now.
#8 FordGT90Concept OFFLINE
FordGT90Concept
    Advanced Member
  • Members
  • 703 posts
Posted 02 October 2016 - 12:01 PM
This appears to be fixed as of 3.1.173.0 beta.
#9 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 149030 posts
Posted 02 October 2016 - 03:23 PM
Thanks for reporting back.
Also tagged with one or more of these keywords: fixed, guide, old data, recordings, Meet the Press
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
