Emby Crashing on Startup Ubuntu 16.04 LTS
mathew.seemon
 Share
mathew.seemon
Hi,
After a recent apt-get dist-upgrade it seems some dependent libraries got messed up and now my Emby Server is not starting up.
I am running Emby Server Version: 3.0.6400. on Ubuntu 16.04.1 LTS.
Attached are some relevant logs I could find under /var/log/
Any help to resolve this would be awesome.
-Matt
dpkg.log
emby-server.log
server-63608630399.txt
server-63608680856.txt
Link to comment
Share on other sites
It's been mentioned in a few other threads, apparently a dependency issue with mono.   If you install mono-complete, it will work again, but you probably don't need all of the packages that it will install...
  • Like 1
Link to comment
mathew.seemon
Thanks... That definitely fixed the problem. plus added a lot of unwanted libraries. I dont know Ubuntu well enough to go messing with it anyways....
Link to comment
 Share
