shimmerknight 5 Posted August 26, 2016 Share Posted August 26, 2016 Ran a sync job on a play list, 300 plus songs. Nice to see that feature btw. There was one song that wasn't syncing for whatever reason. I believe this is the cause of the issue. Well the battery started draining very rapidly. About 1% per minute. Closing the app did not stop the drain. I shut down the phone went to the server and killed the sync for that song. Using a lumia 950 with beta server software on a win10 machine. If you need anything else from me just ask. Log attached. Thanks server-63607620194.txt Link to comment Share on other sites More sharing options...
7illusions 1249 Posted August 26, 2016 Share Posted August 26, 2016 Feels strange that the app should cause that.. What does the battery app show? (Settings -> System -> Battery Battery usage by app.) If it says "Managed by Windows", which it should, there's most likely something else causing the rapid drain. I got a 950 myself, and I haven't seen this. (Not saying you're wrong, just that I don't know how this would be able to happen) Link to comment Share on other sites More sharing options...
shimmerknight 5 Posted August 26, 2016 Author Share Posted August 26, 2016 I did get a screen cap of it at the time. It does say managed. Ya your right it may not be the software. I was just going of the timing of events. Thought you should know though. I'm nice like that. I'll try to see if I can reproduce it tonight when I have time. I remember the song that wasn't sync'ing. Link to comment Share on other sites More sharing options...
