Skipping forward and backwards not working with latest alpha
totalhavoc
 Share
Go to solution Solved by Angelblue05,
I have the latest alpha (2.2.12) loaded because I've been having the library sync issues with the beta server, currently at 3.1.40. If I launch a video on either of our Shield TVs I am unable to skip forward or backwards. The progress bar at the bottom looks like a streaming bar instead of the normal progress bar. If I do the same thing on one of our windows boxes everything works fine, same versions. The only difference is I'm playing using HTTP on Shield and SMB on windows. I have never been able to get SMB to work because I run a windows domain. If I downgrade to 2.2.11 skipping forwards and backwards works fine but I start getting the library sync exited message again. Any idea?
thanks!
Link to comment
Share on other sites
I assumed you updated the one on kodi.emby.media so I pulled it down using that method and it fixed the problem.
  • Like 1
Link to comment
Angelblue05
Indeed - the latest alpha is always uploaded to our no-side loading method. Thanks a lot for confirming it works once again. :)
Link to comment
Guest
 Share
