[BUG] Low quality posters while browsing movies? (4K monitor)
4k posters bug emby
  • Please log in to reply
9 replies to this topic
#1 julianb OFFLINE
julianb
    Advanced Member
  • Members
  • 128 posts
  • Local time: 02:38 PM
  • LocationNorway
Posted 11 April 2016 - 10:08 AM
After the 2.0.0 update all the posters have lesser quality in grid view.
When I enter a movie, it shows it in great quality, but when browsing it shows them with some sort of "compressed" quality that does not look good.
Don't know why this i happening. It only does this on my HTPC connected to my 4K tv.
#2 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 139743 posts
  • Local time: 08:38 AM
Posted 11 April 2016 - 10:37 AM
See if it's any better now.
#3 julianb OFFLINE
julianb
    Advanced Member
  • Members
  • 128 posts
  • LocationNorway
Posted 11 April 2016 - 12:07 PM
Nope, still the same. Version 2.1.6
Everything is crisp (icons etc) but posters are low pq.
Edited by julianb, 11 April 2016 - 12:07 PM.
#4 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 139743 posts
Posted 11 April 2016 - 01:37 PM
The zoom scale up effect is going to have some blur
#5 julianb OFFLINE
julianb
    Advanced Member
  • Members
  • 128 posts
  • LocationNorway
Posted 11 April 2016 - 04:17 PM
I understand that the zoom will have some blur, but if I look at the picture at full size you will see that all the posters have low quality (when selected or not). It was not like this before.
It does not look good when browsing, and some are worse than others. Is there a reason for the "compressed" quality?
#6 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 139743 posts
Posted 11 April 2016 - 04:24 PM
i am not really sure. that shouldn't be happening.
#7 julianb OFFLINE
julianb
    Advanced Member
  • Members
  • 128 posts
  • LocationNorway
Posted 12 April 2016 - 01:28 AM
Okay, will try to reinstall Emby Theater later on. Will also check if it has something to do with scaling in Windows. I think I have 150% scaling when at 4K.
#8 ebr ONLINE
ebr
    Chief Bottle Washer
  • Administrators
  • 47409 posts
Posted 12 April 2016 - 09:07 AM
My money is on that...
#9 julianb OFFLINE
julianb
    Advanced Member
  • Members
  • 128 posts
  • LocationNorway
Posted 12 April 2016 - 09:22 AM
Correct! Turns out that my scaling was on 300% when in 4K mode.
Tried 150% and 100%, both worked perfectly, but now I can't use my HTPC to anything else than EMBY because it is impossible to see anything !
There have to be a way to fix this, because it worked before 2.x.x :)
The app itself looks beautiful and crisp in 4k, and scaling does not impac the UI, only the posters.
#10 Luke OFFLINE
Luke
    System Architect
  • Administrators
  • 139743 posts
Posted 12 April 2016 - 12:57 PM
When you scale the UI it gets blown up, so it's not really 4k anymore, it's more like 1440p or 1080p being upscaled. So the app is going to use poster sizes based on those smaller resolutions, then the OS will blow everything up.
Also tagged with one or more of these keywords: 4k, posters, bug, emby
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
