beta 2.2.2 : small bug in onPlayBackStopped
Laurent_Hubaut
Go to solution Solved by Angelblue05,
Laurent_Hubaut
Hello,
Don't know if this has been already reported but I saw in the kodi logs that the method onPlayBackStopped is calling logMsg instead of log, meaning an exception
Laurent
Link to comment
Share on other sites
  • Solution
Angelblue05
You'll need to update your kodi emby repo to get the latest release version. This has already been fixed (stable is now 2.2.4)
Sent from my iPhone using Tapatalk
  • Like 1
Link to comment
Laurent_Hubaut
You are right, sorry, I didn't know that repo (then addon) were not automatically updated
Thanks
Link to comment
Angelblue05
They are, usually. We needed to update the repository url and therefore it couldn't see the "latest" with the previous repo version. But moving forward, you will receive add-on updates automatically.
Link to comment
Guest
