Correct setup of the Emby for Kodi add-on when running on the same machine
Guest petwri
 Share
Guest petwri
First of all, let me say that I searched the forum and haven't found anything that covers this topic. I have a few questions regarding the setup of Emby together with Kodi when they are running on the same machine, to be precise, a headless Ubuntu-based HTPC.
I scanned my video files to Emby, they show up just fine on the server side. Emby fetches all the artwork properly, including extrafanart and extrathumbs.
I use the Kodi addon (1.1.53) and want to get direct playback running as smooth as possible. As said, Kodi runs on the same device with the same user and same filesystem access. But now a few questions arise:
1. Do I need the option to use local paths instead of Emby redirection enabled? When I do not enable that option, Kodi does not see the extrathumbs Emby provides because the skin needs the actual filepath to see them.
2. Will a path substitution solve the issue mentioned above? My video files are stored under /media/Media, will a substitution /media/Media -> /media/Media make a difference?
3. And, next big issue: I know that Kodi handles music different from the video files. How will path substitution and direct playback work here? How does the add-on provide the music cdart to Kodi? Will it set the item.art(discart) property?
Again, the problem is that the skin I use right now needs the actual filename path for cdart, extrafanart and extrathumb. It would not be a big problem to change the skin a little, but right now I just don't now how because I don't know what artwork is provided to the music.db directly and which not.
Link to comment
Share on other sites
Guest
 Share
