Sign in to follow this
gop
Installing MB 2.6.2 on 8.1 Issues
gop
Hi Guys, anyone know how to install MB 2.6.2 into 8.1, all i get is 3.5 .net or higher issue? Ive .net 4.5. I had the version working fine before, but had HDD problem, now i cant even install it, to correct the config code.
Share this post
Link to post
Share on other sites
gop
I know, but the installer implies , MB 2.6.2 requires.Net 3.5 or higher. I had this version working on 8.1 pro before, which didn't have 3.5 installed. So what's different now with the exact same OS?
Share this post
Link to post
ebr
It requires .net 3.5.1 specifically so be sure to install that.
Share this post
Link to post
gop
Thanks so much, enabled it, it installed, added the config files, so now working. However, I cannot get the iso part to work, I've dameon tools lite installed, and it's the correct path, but MB,reports it's not configured?
Share this post
Link to post
