Steverido 6 Posted August 14, 2015 Share Posted August 14, 2015 I am in the process of setting up my Harmony Ultimate Remote to control WMC & Emby. It was not obvious to setup from Logitech software so I did some research and found a post from Logitech after they had kindly added the function to the remote and software. Here is the instructions if you need them. Device type: Computer -> Media Center PC Manufacturer: Microsoft Model: Windows Media Center SE I want to thank “Bevhoward” for sending us his Windows Media Center keyboard. !!KUDOS!! I would also like to thank my colleague Cristian for creating the IR language and for adding the new device to our database. The Media Center keyboard allowed us to capture the IR codes used to send hotkeys such as “Alt+F4” to close an application directly and “Win+D” to “minimize all” to the desktop. We also captured the mouse commands and an FAQ will follow with button mapping suggestions for the mouse control. Below is a list of the newly added commands/hotkeys: (Please note that these commands may not work on all Media Center IR receivers; the commands have been tested and confirmed working with the original Microsoft IR Receiver) This forum thread is not for MCE users using Imon, Linux or other third party applications and/or IR receivers that do not use the Microsoft IR protocol. Win + - (plus or minus key) Zoom in or out. Win- Win+ Win+Up: Maximize Win+Down: Restore / Minimize Win+Left: Snap to left Win+Right: Snap to right Win+Home: Minimize / Restore all other windows Win+T: Focus the first taskbar entry Win+F: Open Windows search Win+E: Open Windows Explorer Win+Space: Peek at the desktop Win+G: Bring gadgets to the top of the Z-order Win+P: External display options (mirror, extend desktop, etc) Win+M: Minimize all open windows Win+1 / Win+2 / Win+3 etc (Hotkeys for programs added to the Quicklaunch) Win+M: Minimize all open windows Win+Tab: Flip 3D Win+Shift+M: Undo all window minimization Win+Home: Minimize all but the current window Win + L: Lock the computer Win + R: Open ‘Run’ command Alt+1 / Alt+2 Alt+3 etc (Hotkeys for Video card display settings) Alt+Esc: Cycle through all open windows Alt+Tab: Switch to previous active window Alt+Enter: Display properties for the selected item Alt+Space: Pop up window menu Alt+F4: Shutdown current window Ctrl+A: Select all items in a document or window Ctrl+C: Copy the selected item Ctrl+X: Cut the selected item Ctrl+V: Paste the selected item Ctrl+Z: Undo an action Ctrl+W Closes the tabs for most web browsers Ctrl+Shift+Tab: Left Navigation through the web browser tabs Ctrl+Tab: Right Navigation though the web browser tabs Ctrl+ESC: Opens the Start menu Shift+Del: Permently deletes an item and bypasses the recycle bin Shift+F10: Opens Shortcut Menu (Some hotkeys are specifically designed for Windows 7 and may not work on other operating systems) Link to comment Share on other sites More sharing options...
