Emby Server Error: Guid should contain 32 digits with 4 dashes
kakata
 Share
Go to solution Solved by Xtropy,
kakata
Hi
Since new ppa (Version 3.0.5621.3) and the recently updated ubuntu install method (for Version 3.0.5621.4), emby server on Ubuntu 14.04 server presents a Guid should contain 32 digits with 4 dashes error if:
try to add a setting to a current or new user
try to add a new plugin
Here's the error presented when adding an option to a current user:
015-05-30 10:28:11.7699 Error - DtoUtils: ServiceBase<TRequest>::Service Exception
*** Error Report ***
Version: 3.0.5621.4
Command line: /opt/emby-server/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby
Operating system: Unix 3.13.0.52
Processor count: 1
64-Bit OS: True
64-Bit Process: True
Program data path: /var/lib/emby
Mono: 4.0.1 (tarball Tue May 26 04:28:10 UTC 2015)
Application Path: /opt/emby-server/MediaBrowser.Server.Mono.exe
Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx).
System.FormatException
 at System.Guid+GuidResult.SetFailure (ParseFailureKind failure, System.String failureMessageID, System.Object failureMessageFormatArgument, System.String failureArgumentName, System.Exception innerException) [0x00000] in <filename unknown>:0
 at System.Guid+GuidResult.SetFailure (ParseFailureKind failure, System.String failureMessageID) [0x00000] in <filename unknown>:0
 at System.Guid.TryParseGuidWithNoStyle (System.String guidString, System.GuidResult& result) [0x00000] in <filename unknown>:0
 at System.Guid.TryParseGuid (System.String g, GuidStyles flags, System.GuidResult& result) [0x00000] in <filename unknown>:0
 at System.Guid..ctor (System.String g) [0x00000] in <filename unknown>:0
 at MediaBrowser.Server.Implementations.Library.UserManager.GetUserById (System.String id) [0x00000] in <filename unknown>:0
 at MediaBrowser.Api.UserService+<PostAsync>c__async4.MoveNext () [0x00000] in <filename unknown>:0
2015-05-30 10:28:11.7702 Error - HttpServer: Error processing request for /emby/Users/f67e8bfc164e48b8940c911ff981f511
Version: 3.0.5621.4
Processor count: 1
64-Bit OS: True
ServiceStack.HttpError
No Stack Trace Available
Link to comment
Share on other sites
kakata
Ok,
After reinstalling and no success on the above (and other errors), I proceeded and changed to DEBIAN 8 distribution and all functions are normal.
Please if anyone have a successfull Ubuntu 14.04 LTS install and operation, please send kernel version used.
Thanks,
Link to comment
hurricanehrndz
Ok,
Thanks,
That is very strange. I use 14.04 wither kernel  3.8.0-39-generic. What other errors are you seeing other than guid. I'm setting up a new vm to see if I can reproduce your error.
Edited by hurricanehernandez
Link to comment
hurricanehrndz
Just tried with a fresh install of ubuntu minimal 14.04. I followed my own instructions and I received no error about Guid. Using kernel  4.0.0-040000-generic
Link to comment
JoeyMuyo
Just want to chime in if I can. I am getting this GUID error on all my plugins since the changes. Including a new installation of a plugin, trakt, that I never had before.
No amount of reinstalling emby seems to resolve the problem.
The error I get for trakt in the logs are:
2015-06-01 22:15:26.1754 Error - DtoUtils: ServiceBase<TRequest>::Service Exception
	Version: 3.0.5621.4
	Operating system: Unix 3.16.0.38
	Processor count: 4
	64-Bit OS: True
	Mono: 4.0.1 (tarball Tue May 26 04:32:21 UTC 2015)
	at System.Guid/GuidResult.SetFailure (System.Guid/ParseFailureKind,string,object,string,System.Exception) <0x000de>
	at System.Guid/GuidResult.SetFailure (System.Guid/ParseFailureKind,string) <0x0001e>
	at System.Guid.TryParseGuidWithNoStyle (string,System.Guid/GuidResult&) <0x0005a>
	at System.Guid.TryParseGuid (string,System.Guid/GuidStyles,System.Guid/GuidResult&) <0x00247>
	at System.Guid..ctor (string) <0x000e0>
	at MediaBrowser.Api.PluginService.Post (MediaBrowser.Api.UpdatePluginConfiguration) <0x0006c>
	at (wrapper dynamic-method) object.lambda_method (System.Runtime.CompilerServices.Closure,object,object) <0x00074>
	at ServiceStack.Host.ServiceExec`1/<>c__DisplayClass6<MediaBrowser.Api.PluginService>.<CreateExecFn>b__5 (object,object) <0x0002d>
	at ServiceStack.Host.ServiceRunner`1<MediaBrowser.Api.UpdatePluginConfiguration>.Execute (ServiceStack.Web.IRequest,object,MediaBrowser.Api.UpdatePluginConfiguration) <0x00424>
2015-06-01 22:15:26.1754 Error - HttpServer: Error processing request for /emby/Plugins/8abc6789-fde2-4705-8592-4028806fa343/Configuration
	Version: 3.0.5621.4
	Processor count: 4
	64-Bit OS: True
And for Auto Box Set, which was already install I get:
2015-06-01 22:18:31.8208 Error - DtoUtils: ServiceBase<TRequest>::Service Exception
	Version: 3.0.5621.4
	Processor count: 4
	64-Bit OS: True
2015-06-01 22:18:31.8208 Error - HttpServer: Error processing request for /emby/Plugins/899c12c7-5b40-4c4e-9afd-afd74a685eb1/Configuration
	Version: 3.0.5621.4
	Processor count: 4
	64-Bit OS: True
Link to comment
freebs
I brought this to there attention last week, I still see no fix ..?
Any updates to this ?
Thanks.
Link to comment
kakata
Same here, running smooth but after new ppa all got broken. Even after complete reinstall no joy.
My guess is a mono error on the kernel version run in digital ocean vm.
Please post kernel version.
Link to comment
freebs
Here is my kernel version...
root@HTPC:~# uname -a
Linux HTPC 3.13.0-53-generic #89-Ubuntu SMP Wed May 20 10:34:39 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Link to comment
hurricanehrndz
@kakata
What is the kernel version you are using? I haven't tried plugins. I tried only adding users and editing them.
Link to comment
kakata
@hurracainehernandez:
Used 3.13.0-52-generic (also 3.13.0-53-generic) which are the most recent available in Digital Ocean (unsuccessfully).
And yes, I got errors creating users, enabling plugins, loading users avatar image, disabling dna service.
I love Ubuntu and the challenge, but like I said before, all is now working on Debian 8. Nerveless I'm looking forward on the new mono idea!
Link to comment
JoeyMuyo
I am on Ubuntu 14.10 with kernel version 3.16.0-38-generic.
Haven't tried creating users or editing them yet but I am guessing that might also be a problem.
Link to comment
hurricanehrndz
@@JoeyMuyo,
Have you tried updating to kernel 4.04? mono has been updated in our repos.
Link to comment
JoeyMuyo
@@JoeyMuyo,
I have not. I have just recently updated the mono from the repo.
What would be the knock of effect of upgrading to 4.04. Or would upgrading to 15.04 help?
Link to comment
geaves
Luke pointed me here as I posted a problem with Auto Box Sets, however I have just added a user and got the same gui error, but there is more in the log. Having read this thread I have updated kernel to 4.04.
server log.txt
Link to comment
hurricanehrndz
attachicon.gifserver log.txt
Can you guys please tell me if you have done anything with the emby sqlite files.
Link to comment
hurricanehrndz
@@Luke, so this seems to be an sqlite issue:
http://wp.qmatteoq.com/using-sqlite-in-your-windows-8-metro-style-applications/
And emby experience this problem back in 2013 as well:
http://emby.media/community/index.php?/topic/1951-guid-should-contain-32-digits-and-4-dashes-error/
I have two different instances of trusty both not exhibiting this issue, so I am at a loss at what it could be.
Link to comment
Xtropy
I did a complete wipe of Emby and installed from scratch and get this error constantly. I am running Ubuntu 14.04.2 LTS, Trusty Tahr"
There are a number of other posts with this issue on various areas of the forums. This issue began after the PPA changes recently.
Link to comment
hurricanehrndz
@@Xtropy are you using database backup at all? Because the guid issue from what I can tell could be the result of a corrupt database. I have tried to reproduce the error, but I can't on either of my trusty machines.
Link to comment
hurricanehrndz
Can you please post your logs, the more logs we get the better. Please post as much information as possible, host os, cpu, vm anything and everything.
Link to comment
 Share
