jojovee 2 Posted May 4, 2015 Share Posted May 4, 2015 I've had this annoying problem for a while now but have basically been able to ignore it as I haven't had the time to dedicate to this. Scenario is this, I browse my movies by genres, so I have nice folder.png's and backdrops in every genre folder. So when I view it on my tv, I get an image for each genre folder like drama, action, animation etc. I've noticed now however instead of having one image for each genre, some of my genre's are doubling up. In the image below you can see that my drama and family genre's (highlighted in blue)now have two images with the exact number of movies in each and the exact same image. Not too sure what's causing this issue as I've checked all my metadata for my movies and they are all correct. This is occurring in mediabrowser client as well. Any help would be much appreciated. Link to comment Share on other sites More sharing options...
Luke 37046 Posted May 5, 2015 Share Posted May 5, 2015 i don't quite follow. aren't they two separate genres? Link to comment Share on other sites More sharing options...
BuckyBall 2 Posted May 5, 2015 Share Posted May 5, 2015 (edited) Please disregard, misread original post Edited May 5, 2015 by BuckyBall Link to comment Share on other sites More sharing options...
Luke 37046 Posted May 5, 2015 Share Posted May 5, 2015 if you cleared the cache folder then you just need to give it time to reprocess those images and it will be fine Link to comment Share on other sites More sharing options...
BuckyBall 2 Posted May 5, 2015 Share Posted May 5, 2015 (edited) if you cleared the cache folder then you just need to give it time to reprocess those images and it will be fine Sorry deleted original post as it was based on incorrect reasoning. FYI: The cache was deleted yesterday and a scan forced to pick up anything new. Still get blanks in the 'Latest Media' display. Edited May 5, 2015 by BuckyBall Link to comment Share on other sites More sharing options...
Luke 37046 Posted May 5, 2015 Share Posted May 5, 2015 See http://emby.media/community/index.php?/topic/790-how-to-report-a-problem/ Link to comment Share on other sites More sharing options...
BuckyBall 2 Posted May 5, 2015 Share Posted May 5, 2015 Will post logs etc as per your reply. Thanks. Link to comment Share on other sites More sharing options...
jojovee 2 Posted May 6, 2015 Author Share Posted May 6, 2015 Um not too sure what BuckyBall is going on about but Luke in regards to your comment, yes they are two separate genres, family and drama. But as you can see by the screenshot, there is two family folders and two drama folders when there should only be one of each. Link to comment Share on other sites More sharing options...
jojovee 2 Posted June 27, 2015 Author Share Posted June 27, 2015 Further to this as I haven't had any luck yet. I've uninstalled Emby server and emby classic, deleted everything out of my computer, reinstalled everything and let the cache rebuild but I still have two instances of the Drama and Family genre. They both exist in Emby in the browser and Emby classic in media center. Does anyone have any ideas as this is driving me nuts? Link to comment Share on other sites More sharing options...
Happy2Play 8273 Posted June 27, 2015 Share Posted June 27, 2015 Do they both point to the same place if you go to edit? Link to comment Share on other sites More sharing options...
jojovee 2 Posted June 27, 2015 Author Share Posted June 27, 2015 Yes Link to comment Share on other sites More sharing options...
jojovee 2 Posted June 28, 2015 Author Share Posted June 28, 2015 No one? Not even the developers might know what's going on? It has me baffled as to why there's two instances of the drama and family folder which by the way are identical to each other but then the other genres are fine. This is even after a complete uninstall and reinstall. Link to comment Share on other sites More sharing options...
Solution Vidman 589 Posted June 28, 2015 Solution Share Posted June 28, 2015 Maybe you could try the genre cleaner plugin to try and resolve the issue? 1 Link to comment Share on other sites More sharing options...
jojovee 2 Posted June 29, 2015 Author Share Posted June 29, 2015 Is that just in the plugin catalogue? What does it do? I keep my genres quite clean and only like one genre per movie. It doesn't re-download all the metadata does it? Link to comment Share on other sites More sharing options...
Vidman 589 Posted June 29, 2015 Share Posted June 29, 2015 It's in the catalogue, I haven't used it but I believe you chose the genres you want kept and it will remove any genre not on that list Link to comment Share on other sites More sharing options...
jojovee 2 Posted June 29, 2015 Author Share Posted June 29, 2015 I don't see how that will help then as I only have one genre per movie as stated above. If it's a drama movie then the movie will have the genre drama in the metadata and nothing else. The issue is that it's duplicating the movie in another drama genre folder when it shouldn't be. The same goes for the family genre. All the other genres are fine though. It's so weird I'm starting to go bald trying to figure out what's causing it. Link to comment Share on other sites More sharing options...
Vidman 589 Posted June 29, 2015 Share Posted June 29, 2015 Ok it was just a suggestion Link to comment Share on other sites More sharing options...
jojovee 2 Posted June 29, 2015 Author Share Posted June 29, 2015 Sorry didn't mean to sound rude, it was a good suggestion better than none Link to comment Share on other sites More sharing options...
Luke 37046 Posted June 29, 2015 Share Posted June 29, 2015 maybe one of your genres in one of your movies has a trailing or leading space. or a trailing or leading character which is not a valid file system character, which then leads the server to convert that to a space. Link to comment Share on other sites More sharing options...
Vidman 589 Posted June 29, 2015 Share Posted June 29, 2015 maybe one of your genres in one of your movies has a trailing or leading space. or a trailing or leading character which is not a valid file system character, which then leads the server to convert that to a space.That was my thinking, that's why I suggested genre cleaner, But no worries no offence taken:) Link to comment Share on other sites More sharing options...
jojovee 2 Posted June 29, 2015 Author Share Posted June 29, 2015 Thanks both, I'll give genre cleaner a go then. Will be back with an update Link to comment Share on other sites More sharing options...
jojovee 2 Posted June 29, 2015 Author Share Posted June 29, 2015 OMG! Yes!!!!!! That fixed it. There must have been something in those two genres in a movie somewhere that was messing it up. Thank you , thank you, thank you. Link to comment Share on other sites More sharing options...
Vidman 589 Posted June 29, 2015 Share Posted June 29, 2015 You're welcome;) Link to comment Share on other sites More sharing options...
