thefirstofthe300 291 Posted April 13, 2015 Share Posted April 13, 2015 Sorry. Didn't understand what you were trying to say. Link to comment Share on other sites More sharing options...
footose 2 Posted April 13, 2015 Author Share Posted April 13, 2015 (edited) Yup - same problem here - also - haven't had time to download the source to take a look (actually, I did, but I can't get it to compile.. i gave up ).. This is most def a problem. I've already attached both Android and Server logs - and several video's of the issue. What more is required to get this moving? Edited April 13, 2015 by footose Link to comment Share on other sites More sharing options...
Heuer 76 Posted April 13, 2015 Share Posted April 13, 2015 Android 5.1 on Nexus 6. Similar issues. Link to comment Share on other sites More sharing options...
footose 2 Posted April 13, 2015 Author Share Posted April 13, 2015 (edited) I have these EXACT problems. I also reported specifically the Wifi / 4G problem here: Android app only works locally after server update Edited April 13, 2015 by footose Link to comment Share on other sites More sharing options...
iam4uk 26 Posted April 13, 2015 Share Posted April 13, 2015 I have these EXACT problems. I also reported specifically the Wifi / 4G problem here: Android app only works locally after server update Saw your excellent, detailed explanation of some problems in the link you provided. What Android OS version does your device run? Link to comment Share on other sites More sharing options...
iam4uk 26 Posted April 14, 2015 Share Posted April 14, 2015 So many merged topics here, I wonder if any of the issues are being addressed? Link to comment Share on other sites More sharing options...
footose 2 Posted April 17, 2015 Author Share Posted April 17, 2015 This issue persists. Link to comment Share on other sites More sharing options...
Luke 37007 Posted April 17, 2015 Share Posted April 17, 2015 I believe you, it's just that I have been trying to reproduce it but have not been able to. Link to comment Share on other sites More sharing options...
footose 2 Posted April 17, 2015 Author Share Posted April 17, 2015 (edited) 5.1 on Nexus 5. 3.4.0-g8a80a0e kernel, build LMy47D Can I help somehow in reproducing the issue? What do you need from us to do so. Edited April 17, 2015 by footose Link to comment Share on other sites More sharing options...
Luke 37007 Posted April 17, 2015 Share Posted April 17, 2015 I've got a nexus 5 here as well, plus a few different devices in the emulator. I guess I would first try updating the server to the new release and clearing app data from the device. then we'll take it from there. Link to comment Share on other sites More sharing options...
davedick 17 Posted April 18, 2015 Share Posted April 18, 2015 (edited) Hi Everyone, First I apologize if I should start a separate thread, but I'm also having issues with the android app, if it's not connected to the home network. When I try to play a recorded show or live show (while connected to the cellular network), I get the spinning circle & after about 30 seconds or so, it will go back to the channel, I tried watching or back to the recorded TV show list. When I look at the logs, it appears to be an FFMPEG error. However that being said, If I try watching the same channel on my android phone, while connected to my wireless router, then It plays just fine. As far as it being a not enough bandwidth issue (my upload is 10 Mbps), I was able to connect from my parents machine & play back a recorded or live show with no issues. Here is the transcoding log while connected on cell network: ffmpeg version N-71182-g5cba529 Copyright © 2000-2015 the FFmpeg developers built with gcc 4.9.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib libavutil 54. 21.100 / 54. 21.100 libavcodec 56. 32.100 / 56. 32.100 libavformat 56. 27.100 / 56. 27.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 13.101 / 5. 13.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100[mpeg2video @ 0000000002caf7a0] Invalid frame dimensions 0x0. Last message repeated 11 times[mpegts @ 000000000033ca60] Could not find codec parameters for stream 2 (Unknown: none ([6][0][0][0] / 0x0006)): unknown codecConsider increasing the value for the 'analyzeduration' and 'probesize' optionsInput #0, mpegts, from 'http://192.168.0.39:5004/auto/v7': Duration: N/A, start: 35861.944433, bitrate: N/A Program 202 Stream #0:0[0xdd8]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv), 704x480 [sAR 10:11 DAR 4:3], max. 15000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Stream #0:1[0xdd9]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:2[0xdda]: Unknown: none ([6][0][0][0] / 0x0006)[libx264 @ 00000000052b87e0] Value -124000.000000 for parameter 'maxrate' out of range [0 - 2.14748e+009][libx264 @ 00000000052b87e0] Error setting option maxrate to value -124000.Output #0, hls, to 'C:\Users\Main\AppData\Roaming\MediaBrowser-Server\transcoding-temp\cf45da384cf33ea316470a36d729eaef.m3u8': Stream #0:0: Video: h264, none, q=2-31, 128 kb/s, SAR 212:213 DAR 0:0, 29.97 fps Metadata: encoder : Lavc56.32.100 libx264 Stream #0:1: Audio: aac, 0 channels, 128 kb/s Metadata: encoder : Lavc56.32.100 aacStream mapping: Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> aac (native))Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height Here is the transcoding log while connected to my wireless network C:\Users\Main\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe -fflags +genpts -i "http://192.168.0.39:5004/auto/v7" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 5362000 -bufsize 10724000 -vsync vfr -level 40 -force_key_frames expr:gte(t,n_forced*3) -vf "scale=min(iw\,2160):trunc(ow/dar/2)*2" -sc_threshold 0 -codec:a:0 aac -strict experimental -ac 2 -ab 510000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 0 -hls_list_size 0 -hls_base_url "hls/183d5a8db8c01befba39b34765256a1f/" -y "C:\Users\Main\AppData\Roaming\MediaBrowser-Server\transcoding-temp\183d5a8db8c01befba39b34765256a1f.m3u8" ffmpeg version N-71182-g5cba529 Copyright © 2000-2015 the FFmpeg developers built with gcc 4.9.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib libavutil 54. 21.100 / 54. 21.100 libavcodec 56. 32.100 / 56. 32.100 libavformat 56. 27.100 / 56. 27.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 13.101 / 5. 13.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100[mpeg2video @ 0000000002e6f7a0] Invalid frame dimensions 0x0. Last message repeated 7 times[mpegts @ 000000000035ca80] Could not find codec parameters for stream 2 (Unknown: none ([6][0][0][0] / 0x0006)): unknown codecConsider increasing the value for the 'analyzeduration' and 'probesize' optionsInput #0, mpegts, from 'http://192.168.0.39:5004/auto/v7': Duration: N/A, start: 36063.384433, bitrate: N/A Program 202 Stream #0:0[0xdd8]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv), 704x480 [sAR 10:11 DAR 4:3], max. 15000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Stream #0:1[0xdd9]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:2[0xdda]: Unknown: none ([6][0][0][0] / 0x0006)[libx264 @ 0000000005891080] using SAR=1/1[libx264 @ 0000000005891080] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 LZCNT[libx264 @ 0000000005891080] profile High, level 4.0Output #0, hls, to 'C:\Users\Main\AppData\Roaming\MediaBrowser-Server\transcoding-temp\183d5a8db8c01befba39b34765256a1f.m3u8': Metadata: encoder : Lavf56.27.100 Stream #0:0: Video: h264 (libx264), yuv420p, 704x528 [sAR 1:1 DAR 4:3], q=-1--1, max. 5362 kb/s, 29.97 fps, 90k tbn, 29.97 tbc Metadata: encoder : Lavc56.32.100 libx264 Stream #0:1: Audio: aac, 48000 Hz, stereo, fltp, 510 kb/s Metadata: encoder : Lavc56.32.100 aacStream mapping: Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> aac (native))Press [q] to stop, [?] for helpframe= 157 fps=0.0 q=24.0 size=N/A time=00:00:05.39 bitrate=N/A frame= 174 fps=170 q=25.0 size=N/A time=00:00:06.03 bitrate=N/A frame= 190 fps=122 q=23.0 size=N/A time=00:00:06.50 bitrate=N/A frame= 203 fps= 99 q=24.0 size=N/A time=00:00:07.06 bitrate=N/A frame= 220 fps= 86 q=25.0 size=N/A time=00:00:07.63 bitrate=N/A frame= 235 fps= 77 q=25.0 size=N/A time=00:00:08.10 bitrate=N/A frame= 252 fps= 71 q=23.0 size=N/A time=00:00:08.59 bitrate=N/A frame= 266 fps= 65 q=26.0 size=N/A time=00:00:09.06 bitrate=N/A frame= 280 fps= 61 q=23.0 size=N/A time=00:00:09.55 bitrate=N/A frame= 294 fps= 58 q=25.0 size=N/A time=00:00:10.06 bitrate=N/A frame= 309 fps= 55 q=24.0 size=N/A time=00:00:10.58 bitrate=N/A frame= 328 fps= 53 q=23.0 size=N/A time=00:00:11.15 bitrate=N/A frame= 345 fps= 52 q=24.0 size=N/A time=00:00:11.64 bitrate=N/A frame= 356 fps= 50 q=27.0 size=N/A time=00:00:12.13 bitrate=N/A frame= 371 fps= 48 q=24.0 size=N/A time=00:00:12.69 bitrate=N/A frame= 388 fps= 47 q=25.0 size=N/A time=00:00:13.22 bitrate=N/A frame= 407 fps= 46 q=23.0 size=N/A time=00:00:13.73 bitrate=N/A frame= 423 fps= 46 q=22.0 size=N/A time=00:00:14.35 bitrate=N/A frame= 437 fps= 45 q=24.0 size=N/A time=00:00:14.82 bitrate=N/A frame= 453 fps= 44 q=24.0 size=N/A time=00:00:15.31 bitrate=N/A frame= 467 fps= 43 q=25.0 size=N/A time=00:00:15.82 bitrate=N/A frame= 485 fps= 43 q=23.0 size=N/A time=00:00:16.31 bitrate=N/A frame= 499 fps= 42 q=24.0 size=N/A time=00:00:16.91 bitrate=N/A frame= 514 fps= 42 q=25.0 size=N/A time=00:00:17.38 bitrate=N/A frame= 529 fps= 41 q=24.0 size=N/A time=00:00:17.87 bitrate=N/A frame= 545 fps= 41 q=26.0 size=N/A time=00:00:18.41 bitrate=N/A frame= 561 fps= 40 q=25.0 size=N/A time=00:00:18.98 bitrate=N/A frame= 576 fps= 40 q=25.0 size=N/A time=00:00:19.47 bitrate=N/A frame= 594 fps= 40 q=22.0 size=N/A time=00:00:19.98 bitrate=N/A frame= 607 fps= 39 q=-1.0 Lsize=N/A time=00:00:20.72 bitrate=N/A video:2366kB audio:1261kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown[libx264 @ 0000000005891080] frame I:7 Avg QP:16.44 size: 23633[libx264 @ 0000000005891080] frame P:156 Avg QP:19.55 size: 6874[libx264 @ 0000000005891080] frame B:444 Avg QP:22.37 size: 2669[libx264 @ 0000000005891080] consecutive B-frames: 2.0% 1.0% 1.5% 95.6%[libx264 @ 0000000005891080] mb I I16..4: 40.6% 22.2% 37.2%[libx264 @ 0000000005891080] mb P I16..4: 7.0% 3.8% 1.1% P16..4: 43.7% 0.0% 0.0% 0.0% 0.0% skip:44.4%[libx264 @ 0000000005891080] mb B I16..4: 1.1% 0.4% 0.0% B16..8: 13.9% 0.0% 0.0% direct:10.8% skip:73.8% L0:27.8% L1:46.5% BI:25.8%[libx264 @ 0000000005891080] 8x8 transform intra:28.4% inter:42.2%[libx264 @ 0000000005891080] coded y,uvDC,uvAC intra: 35.4% 42.1% 17.1% inter: 10.3% 13.0% 0.5%[libx264 @ 0000000005891080] i16 v,h,dc,p: 60% 26% 10% 4%[libx264 @ 0000000005891080] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 18% 31% 5% 4% 3% 5% 4% 6%[libx264 @ 0000000005891080] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 31% 10% 5% 5% 6% 6% 5% 7%[libx264 @ 0000000005891080] i8c dc,h,v,p: 55% 17% 20% 8%[libx264 @ 0000000005891080] Weighted P-Frames: Y:1.3% UV:0.0%[libx264 @ 0000000005891080] kb/s:957.00 Edited April 18, 2015 by davedick Link to comment Share on other sites More sharing options...
Luke 37007 Posted April 18, 2015 Share Posted April 18, 2015 Hi Everyone, First I apologize if I should start a separate thread, but I'm also having issues with the android app, if it's not connected to the home network. When I try to play a recorded show or live show (while connected to the cellular network), I get the spinning circle & after about 30 seconds or so, it will go back to the channel, I tried watching or back to the recorded TV show list. When I look at the logs, it appears to be an FFMPEG error. However that being said, If I try watching the same channel on my android phone, while connected to my wireless router, then It plays just fine. As far as it being a not enough bandwidth issue (my upload is 10 Mbps), I was able to connect from my parents machine & play back a recorded or live show with no issues. Here is the transcoding log while connected on cell network: ffmpeg version N-71182-g5cba529 Copyright © 2000-2015 the FFmpeg developers built with gcc 4.9.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib libavutil 54. 21.100 / 54. 21.100 libavcodec 56. 32.100 / 56. 32.100 libavformat 56. 27.100 / 56. 27.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 13.101 / 5. 13.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 [mpeg2video @ 0000000002caf7a0] Invalid frame dimensions 0x0. Last message repeated 11 times [mpegts @ 000000000033ca60] Could not find codec parameters for stream 2 (Unknown: none ([6][0][0][0] / 0x0006)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpegts, from 'http://192.168.0.39:5004/auto/v7': Duration: N/A, start: 35861.944433, bitrate: N/A Program 202 Stream #0:0[0xdd8]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv), 704x480 [sAR 10:11 DAR 4:3], max. 15000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Stream #0:1[0xdd9]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:2[0xdda]: Unknown: none ([6][0][0][0] / 0x0006) [libx264 @ 00000000052b87e0] Value -124000.000000 for parameter 'maxrate' out of range [0 - 2.14748e+009] [libx264 @ 00000000052b87e0] Error setting option maxrate to value -124000. Output #0, hls, to 'C:\Users\Main\AppData\Roaming\MediaBrowser-Server\transcoding-temp\cf45da384cf33ea316470a36d729eaef.m3u8': Stream #0:0: Video: h264, none, q=2-31, 128 kb/s, SAR 212:213 DAR 0:0, 29.97 fps Metadata: encoder : Lavc56.32.100 libx264 Stream #0:1: Audio: aac, 0 channels, 128 kb/s Metadata: encoder : Lavc56.32.100 aac Stream mapping: Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> aac (native)) Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height Here is the transcoding log while connected to my wireless network C:\Users\Main\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe -fflags +genpts -i "http://192.168.0.39:5004/auto/v7" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -maxrate 5362000 -bufsize 10724000 -vsync vfr -level 40 -force_key_frames expr:gte(t,n_forced*3) -vf "scale=min(iw\,2160):trunc(ow/dar/2)*2" -sc_threshold 0 -codec:a:0 aac -strict experimental -ac 2 -ab 510000 -af "adelay=1,aresample=async=1" -hls_time 3 -start_number 0 -hls_list_size 0 -hls_base_url "hls/183d5a8db8c01befba39b34765256a1f/" -y "C:\Users\Main\AppData\Roaming\MediaBrowser-Server\transcoding-temp\183d5a8db8c01befba39b34765256a1f.m3u8" ffmpeg version N-71182-g5cba529 Copyright © 2000-2015 the FFmpeg developers built with gcc 4.9.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib libavutil 54. 21.100 / 54. 21.100 libavcodec 56. 32.100 / 56. 32.100 libavformat 56. 27.100 / 56. 27.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 13.101 / 5. 13.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 [mpeg2video @ 0000000002e6f7a0] Invalid frame dimensions 0x0. Last message repeated 7 times [mpegts @ 000000000035ca80] Could not find codec parameters for stream 2 (Unknown: none ([6][0][0][0] / 0x0006)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpegts, from 'http://192.168.0.39:5004/auto/v7': Duration: N/A, start: 36063.384433, bitrate: N/A Program 202 Stream #0:0[0xdd8]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv), 704x480 [sAR 10:11 DAR 4:3], max. 15000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Stream #0:1[0xdd9]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:2[0xdda]: Unknown: none ([6][0][0][0] / 0x0006) [libx264 @ 0000000005891080] using SAR=1/1 [libx264 @ 0000000005891080] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 LZCNT [libx264 @ 0000000005891080] profile High, level 4.0 Output #0, hls, to 'C:\Users\Main\AppData\Roaming\MediaBrowser-Server\transcoding-temp\183d5a8db8c01befba39b34765256a1f.m3u8': Metadata: encoder : Lavf56.27.100 Stream #0:0: Video: h264 (libx264), yuv420p, 704x528 [sAR 1:1 DAR 4:3], q=-1--1, max. 5362 kb/s, 29.97 fps, 90k tbn, 29.97 tbc Metadata: encoder : Lavc56.32.100 libx264 Stream #0:1: Audio: aac, 48000 Hz, stereo, fltp, 510 kb/s Metadata: encoder : Lavc56.32.100 aac Stream mapping: Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> aac (native)) Press [q] to stop, [?] for help frame= 157 fps=0.0 q=24.0 size=N/A time=00:00:05.39 bitrate=N/A frame= 174 fps=170 q=25.0 size=N/A time=00:00:06.03 bitrate=N/A frame= 190 fps=122 q=23.0 size=N/A time=00:00:06.50 bitrate=N/A frame= 203 fps= 99 q=24.0 size=N/A time=00:00:07.06 bitrate=N/A frame= 220 fps= 86 q=25.0 size=N/A time=00:00:07.63 bitrate=N/A frame= 235 fps= 77 q=25.0 size=N/A time=00:00:08.10 bitrate=N/A frame= 252 fps= 71 q=23.0 size=N/A time=00:00:08.59 bitrate=N/A frame= 266 fps= 65 q=26.0 size=N/A time=00:00:09.06 bitrate=N/A frame= 280 fps= 61 q=23.0 size=N/A time=00:00:09.55 bitrate=N/A frame= 294 fps= 58 q=25.0 size=N/A time=00:00:10.06 bitrate=N/A frame= 309 fps= 55 q=24.0 size=N/A time=00:00:10.58 bitrate=N/A frame= 328 fps= 53 q=23.0 size=N/A time=00:00:11.15 bitrate=N/A frame= 345 fps= 52 q=24.0 size=N/A time=00:00:11.64 bitrate=N/A frame= 356 fps= 50 q=27.0 size=N/A time=00:00:12.13 bitrate=N/A frame= 371 fps= 48 q=24.0 size=N/A time=00:00:12.69 bitrate=N/A frame= 388 fps= 47 q=25.0 size=N/A time=00:00:13.22 bitrate=N/A frame= 407 fps= 46 q=23.0 size=N/A time=00:00:13.73 bitrate=N/A frame= 423 fps= 46 q=22.0 size=N/A time=00:00:14.35 bitrate=N/A frame= 437 fps= 45 q=24.0 size=N/A time=00:00:14.82 bitrate=N/A frame= 453 fps= 44 q=24.0 size=N/A time=00:00:15.31 bitrate=N/A frame= 467 fps= 43 q=25.0 size=N/A time=00:00:15.82 bitrate=N/A frame= 485 fps= 43 q=23.0 size=N/A time=00:00:16.31 bitrate=N/A frame= 499 fps= 42 q=24.0 size=N/A time=00:00:16.91 bitrate=N/A frame= 514 fps= 42 q=25.0 size=N/A time=00:00:17.38 bitrate=N/A frame= 529 fps= 41 q=24.0 size=N/A time=00:00:17.87 bitrate=N/A frame= 545 fps= 41 q=26.0 size=N/A time=00:00:18.41 bitrate=N/A frame= 561 fps= 40 q=25.0 size=N/A time=00:00:18.98 bitrate=N/A frame= 576 fps= 40 q=25.0 size=N/A time=00:00:19.47 bitrate=N/A frame= 594 fps= 40 q=22.0 size=N/A time=00:00:19.98 bitrate=N/A frame= 607 fps= 39 q=-1.0 Lsize=N/A time=00:00:20.72 bitrate=N/A video:2366kB audio:1261kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 0000000005891080] frame I:7 Avg QP:16.44 size: 23633 [libx264 @ 0000000005891080] frame P:156 Avg QP:19.55 size: 6874 [libx264 @ 0000000005891080] frame B:444 Avg QP:22.37 size: 2669 [libx264 @ 0000000005891080] consecutive B-frames: 2.0% 1.0% 1.5% 95.6% [libx264 @ 0000000005891080] mb I I16..4: 40.6% 22.2% 37.2% [libx264 @ 0000000005891080] mb P I16..4: 7.0% 3.8% 1.1% P16..4: 43.7% 0.0% 0.0% 0.0% 0.0% skip:44.4% [libx264 @ 0000000005891080] mb B I16..4: 1.1% 0.4% 0.0% B16..8: 13.9% 0.0% 0.0% direct:10.8% skip:73.8% L0:27.8% L1:46.5% BI:25.8% [libx264 @ 0000000005891080] 8x8 transform intra:28.4% inter:42.2% [libx264 @ 0000000005891080] coded y,uvDC,uvAC intra: 35.4% 42.1% 17.1% inter: 10.3% 13.0% 0.5% [libx264 @ 0000000005891080] i16 v,h,dc,p: 60% 26% 10% 4% [libx264 @ 0000000005891080] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 18% 31% 5% 4% 3% 5% 4% 6% [libx264 @ 0000000005891080] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 31% 10% 5% 5% 6% 6% 5% 7% [libx264 @ 0000000005891080] i8c dc,h,v,p: 55% 17% 20% 8% [libx264 @ 0000000005891080] Weighted P-Frames: Y:1.3% UV:0.0% [libx264 @ 0000000005891080] kb/s:957.00 This is fixed by the dev server if you want to grab that. If not we'll have a release out soon to address it. Link to comment Share on other sites More sharing options...
davedick 17 Posted April 19, 2015 Share Posted April 19, 2015 I'm willing to try it, but not sure the link to the dev server. This is fixed by the dev server if you want to grab that. If not we'll have a release out soon to address it. Link to comment Share on other sites More sharing options...
Luke 37007 Posted April 19, 2015 Share Posted April 19, 2015 I'm willing to try it, but not sure the link to the dev server. In advanced, set your update level to Dev and then restart the server. After receiving the update you will probably want to change the update level back to Stable to avoid the constant stream of Dev-level server updates. Link to comment Share on other sites More sharing options...
thefirstofthe300 291 Posted April 19, 2015 Share Posted April 19, 2015 In advanced, set your update level to Dev and then restart the server. After receiving the update you will probably want to change the update level back to Stable to avoid the constant stream of Dev-level server updates. And if you are running Linux, it will take a little more than that. Let us know if you are. Link to comment Share on other sites More sharing options...
davedick 17 Posted April 19, 2015 Share Posted April 19, 2015 Not running Linux, just Windows. And if you are running Linux, it will take a little more than that. Let us know if you are. Link to comment Share on other sites More sharing options...
