Serious frame drops on MKV/AC3 movies
EduardoSantos
 Share
EduardoSantos
I am experiencing serious frame drops on several movies when played on any of my Roku3 devices.
Movies are played directly (without transcoding) but the image has little movement: it seems a sequence of stills with a lot of frames dropped in between them.
Same movies play fine on Windows 8 app (direct play) and on Chrome browser (transcoded).
This does not occur with all movies, so I did lots of tests to better determine the scenario (e.g.: codecs) that causes this phenomenon.
The common factors to every movie with this problem are:
Container: MKV
Audio: AC3
AVIs with AC3 audio streams are not problem as they all get transcoded.
I disabled AC3 (DD) passthrough on the Roku configuration. This setup made MKVs with AC3 audio streams to be transcoded. As they are transcoded they play fine with no jitter/frame drops.
This is, though, no solution: disabling AC3 also disables DTS and thus all movies are transcoded resulting on only on 2 audio channels.
I suspect this problem relates to Roku's new firmware as these movies used to play fine on same Rokus.
So if anybody could just test MKVs/AC3 on a Roku and share the result it would be very good.
My setup is as it follows:
MB Server version: 3.0.5518.7
Roku app version: 1.87
Roku firmware version: 6.1 build 5604
Edited by EduardoSantos
Link to comment
Share on other sites
 Share
