MB running on FreeNAS - doesn't recognizes any media
Noisefull
 Share
Hey there guys,
Im reading around here for quite a while now, and the first thing I would like to start off with is saying that you developers and community members are doing great work with your interest and proactivity in your help on every kind of issue brought to your forum. In my opinion this adds a big bunch of remarkable service quality to a plugin thats already great and free.
So here is my problem:
I have MB successfully running and accessible on FreeNAS-9.3-STABLE-20150227075 (installed via implemented Plugin Management), with a mounted storage in the related jail and a few small files in (.mkv and .jpg) inside. I also added the containing folder to the MB Library but MB doesn't recognize any movie or picture to view. Are there any things I probably could have missed setting MB/my library? Do I have to set special permissions?
Please excuse me if forgot some important information about my setup.
Link to comment
Share on other sites
josh4trunks
MB needs read permissions for the files. if they're the usual 755 they should be readable, you might want to check that.
Link to comment
 Share
