Koleckai Silvestri 1150 Posted January 5, 2015 Share Posted January 5, 2015 How can I bypass the Connect portion completely? Every time the Roku App is launched, it asks me to enter in a Pin Number at the connect site and refuses to connect to the previously established server. The only way to connect is to enter in the server's IP address every time. It is creating a lot of grief in the family. I do not want to connect my collection to a site outside my network. Link to comment Share on other sites More sharing options...
ebr 14904 Posted January 5, 2015 Share Posted January 5, 2015 Make sure the server is running and is discoverable on the network. Then it should find it automatically. Link to comment Share on other sites More sharing options...
Koleckai Silvestri 1150 Posted January 5, 2015 Author Share Posted January 5, 2015 (edited) It is running and discoverable on the network. The Roku does not find it automatically. In fact, if you choose the server off the list of known servers, it says "Cannot Connect". The only way to connect is by entering in the IP Addresses every time you run the app. The server is used on 15 other devices (laptops, tablets, phones, Xbox One, etc...) on the network using the Web Client without problem. It is only the two Rokus that have this problem. Both are connected via Gigabit Ethernet and on the same subnet. The media browser server has a static IP address of 10.0.0.5. Gateway is 10.0.0.1. Router #1 is 10.0.0.2. Router #2 is 10.0.0.3. The Rokus have dynamic IP addresses of 10.0.0.146 and 10.0.0.199. Of course those can change as devices renew leases and power up and off. Server Version is 3.0.5482.0. Though it happened in the previous version as well. Reinstalled the server completely right before Christmas. New Storage System, New OS, Same CPU and MAC ID. No data was maintained from the previous installation. IP Address of the server is the same as it was before the reinstall though. No other Roku channels/apps have problems. Edited January 5, 2015 by Koleckai Silvestri Link to comment Share on other sites More sharing options...
Koleckai Silvestri 1150 Posted January 5, 2015 Author Share Posted January 5, 2015 (edited) I have the following Firewall rules set up: mediabrowser.serverapplication,exe - inbound, all ports, UDP, Domain, Private. mediabrowser.serverapplication.exe - inbound, all ports, TCP, Domain, Private. Port 8096 - All Applications, TCP, Public, Private, Domain Port 7359 = All Applications, UDP, Public, Private, Domain Inbound rules verified using this guide: http://mediabrowser.tv/community/index.php?/topic/6763-media-browser-for-roku/?p=92778 These ports are not open to external connections on the router. Doesn't appear that the Server installation created any outbound rules. Machine is on the same Workgroup, a member of the Homegroup and has File and Printer Sharing On. Once connected via IP address, everything works in the Roku client. Until you close the app and return to the Roku homescreen. Then you have to start over. Downloaded and installed the latest versions of MediaBrowser Theater, MediaBrowser for iOS and Media Browser for Android. All three of these client immediately found and connected to the server across multiple devices. Edited January 5, 2015 by Koleckai Silvestri Link to comment Share on other sites More sharing options...
Luke 37018 Posted January 6, 2015 Share Posted January 6, 2015 we should get to the bottom of why you cant' connect locally. can you try the zip file installation and then gather a roku log? thanks. Link to comment Share on other sites More sharing options...
Koleckai Silvestri 1150 Posted January 6, 2015 Author Share Posted January 6, 2015 (edited) How do you turn on logging for the roku client? Can't see any options for it. Get this error when trying to install from the ZIP on github: Warning: Application size limits it to Roku 2 players, Roku XDS and Roku XR. It will not work with other Roku 1 players (1511026 > 768000). Install Failure: No manifest. Invalid package. Which is strange since it is a Roku 3 (5000 model). Edited January 6, 2015 by Koleckai Silvestri Link to comment Share on other sites More sharing options...
Luke 37018 Posted January 6, 2015 Share Posted January 6, 2015 see here http://mediabrowser.tv/community/index.php?/topic/16251-how-to-obtain-a-log-from-the-media-browser-roku-client/ you can start with post #5 since you've done everything before that already Link to comment Share on other sites More sharing options...
Koleckai Silvestri 1150 Posted January 6, 2015 Author Share Posted January 6, 2015 Got the zip channel installed. Will get logs when the device is available. Link to comment Share on other sites More sharing options...
Koleckai Silvestri 1150 Posted January 6, 2015 Author Share Posted January 6, 2015 It appears it is trying to connect to the external IP even though it isn't available. o pop screen that doesn't match the top of our stack! Removing screen 7 from middle of stack! OnPasswordEntered Popping screen 8 and cleaning up 1 breadcrumbs Top of stack is once again: Server List Popping screen 2 and cleaning up 1 breadcrumbs Top of stack is once again: ConnectSignIn Popping screen 1 and cleaning up 1 breadcrumbs Pushing screen 9 onto view controller stack - Home Loading beginning of row 0, Collections Loading beginning of row 1, Movies Total initial grid load took: 24ms Popping screen 9 and cleaning up 0 breadcrumbs Popping home screen Pushing screen 10 onto view controller stack - Home Loading beginning of row 0, Collections Loading beginning of row 1, Movies Total initial grid load took: 21ms Count loaded is now 8 out of 80 Loaded 8 elements in row 0, now have 80 Count loaded is now 10 out of 60 Loaded 10 elements in row 1, now have 60 Count loaded is now 10 out of 60 Loaded 10 elements in row 2, now have 60 Received paginated response for index 8 of list with length 80 Count loaded is now 80 out of 80 Loaded 72 elements in row 0, now have 80 Received paginated response for index 10 of list with length 60 Count loaded is now 85 out of 77 Loaded 75 elements in row 1, now have 77 Received paginated response for index 10 of list with length 60 Count loaded is now 85 out of 77 Loaded 75 elements in row 2, now have 77 Count loaded is now 29 out of 29 Loaded 29 elements in row 3, now have 29 Count loaded is now 1 out of 1 Loaded 1 elements in row 4, now have 1 Count loaded is now 4 out of 4 Loaded 4 elements in row 5, now have 4 Popping screen 10 and cleaning up 0 breadcrumbs Popping home screen Finished global message loop ------ Running ------ --1.77 Anamorphic support: true Server.info: listening on 0.0.0.0:8324 Using broadcast address 10.0.0.255 Send To Address: 10.0.0.255:7359 / 10.0.0.255:7359 Cancel UDP Broadcast Found 0 servers Connect returned 0 servers Creating server data cache Found string in the registry: {"a858d557961fda717a8be4ac17e5a055":{"AccessToken":"f7562d1967cf4ec58bfef6c62343246b","UserId":"a6737ecaf246ef2235c4bee1f90ac99f","RemoteAddress":"http://104.33.171.64:8096","LastAccess":"1420517315","Name":"WayneFlix","ManualAddress":"http://10.0.0.5:8096","LocalAddress":"http://10.0.0.5:8096","id":"a858d557961fda717a8be4ac17e5a055"}} Parsed as: roAssociativeArray connectionManagerGetServers returning 1 servers connectToServers called with 1 servers Attempting to connect to http://104.33.171.64:8096/mediabrowser/system/info/public?format=json AsyncGetToString timeout Failed to get Server Info connectInitial returned State of ConnectSignIn connectInitial returned ConnectionMode of Manual Processing ConnectionResult State of ConnectSignIn Entered CreateScreenForItem Not sure what to do with breadcrumbs on screen type: roCodeRegistrationScreen Pushing screen 1 onto view controller stack - ConnectSignIn Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Using broadcast address 10.0.0.255 Send To Address: 10.0.0.255:7359 / 10.0.0.255:7359 Cancel UDP Broadcast Found 0 servers Connect returned 0 servers connectionManagerGetServers returning 1 servers connectToServers called with 1 servers Attempting to connect to http://104.33.171.64:8096/mediabrowser/system/info/public?format=json AsyncGetToString timeout Failed to get Server Info Processing ConnectionResult State of ServerSelection Using broadcast address 10.0.0.255 Send To Address: 10.0.0.255:7359 / 10.0.0.255:7359 Cancel UDP Broadcast Found 0 servers Connect returned 0 servers connectionManagerGetServers returning 1 servers Pushing screen 2 onto view controller stack - Server List Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Not sure what to do with breadcrumbs on screen type: Invalid Pushing screen 3 onto view controller stack - Dialog: Select Action Creating new dialog Button pressed: 1 Popping screen 3 and cleaning up 0 breadcrumbs Top of stack is once again: Server List Attempting to connect to http://104.33.171.64:8096/mediabrowser/system/info/public?format=json AsyncGetToString timeout Failed to get Server Info Not sure what to do with breadcrumbs on screen type: Invalid Pushing screen 4 onto view controller stack - Dialog: Unable To Connect Creating new dialog Button pressed: Back Popping screen 4 and cleaning up 0 breadcrumbs Top of stack is once again: Server List Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Pushing screen 5 onto view controller stack - Keyboard: Server IP Address (ex. 192.168.1.100) Starting blocking loop for keyboard screen roKeyboardScreenEvent roKeyboardScreenEvent Exiting keyboard screen - ID: 5 Popping screen 5 and cleaning up 1 breadcrumbs Top of stack is once again: Server List Pushing screen 6 onto view controller stack - Keyboard: Server Port # Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} roKeyboardScreenEvent onServerConfigurationUserInput - port Attempting to connect to http://10.0.0.5:8096/mediabrowser/system/info/public?format=json Attempting to connect to http://10.0.0.5:8096/mediabrowser/system/info/public?format=json Processing ConnectionResult State of ServerSignIn ServerSignIn Id: a858d557961fda717a8be4ac17e5a055 ServerSignIn Name: WayneFlix ServerSignIn LocalAddress: http://10.0.0.5:8096 ServerSignIn RemoteAddress: http://104.33.171.64:8096 ServerSignIn ManualAddress: http://10.0.0.5:8096 Pushing screen 7 onto view controller stack - Login getPublicUserProfiles url: http://10.0.0.5:8096 Showing screen with 9 elements roKeyboardScreenEvent Exiting keyboard screen - ID: 6 Trying to pop screen that doesn't match the top of our stack! Removing screen 6 from middle of stack! Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Sending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} ^ASending pin poll request to https://connect.mediabrowser.tv/service/pin?pin=11447&deviceId=1GN38X007949 Poll result: {"Id":"45275","Pin":"11447","DeviceId":"1GN38X007949","IsExpired":false,"IsConfirmed":false,"AccessToken":""} Link to comment Share on other sites More sharing options...
Koleckai Silvestri 1150 Posted January 6, 2015 Author Share Posted January 6, 2015 After that it continues to poll mediabrowser.tv for Pin Authorization. Which is what I don't want. I want it to store the server information provided and to only use that server information. Link to comment Share on other sites More sharing options...
ebr 14904 Posted January 6, 2015 Share Posted January 6, 2015 The root of the problem is the fact that it isn't using the local address. This happened in another case recently and adjusting some firewall settings cleared it up. I thought it had to do with UDP traffic but Luke says that is not the case but check your firewall rules and be sure all traffic is being allowed for the server. Link to comment Share on other sites More sharing options...
Koleckai Silvestri 1150 Posted January 6, 2015 Author Share Posted January 6, 2015 (edited) My firewall settings for MediaBrowser are listed in post #4. Those are the settings that installing the server created. mediabrowser.serverapplication,exe - inbound, all ports, UDP, Domain, Private. mediabrowser.serverapplication.exe - inbound, all ports, TCP, Domain, Private. Port 8096 - All Applications, TCP, Public, Private, Domain Port 7359 = All Applications, UDP, Public, Private, Domain Edited January 6, 2015 by Koleckai Silvestri Link to comment Share on other sites More sharing options...
Koleckai Silvestri 1150 Posted January 6, 2015 Author Share Posted January 6, 2015 What should be changed? Link to comment Share on other sites More sharing options...
ebr 14904 Posted January 6, 2015 Share Posted January 6, 2015 I'm not sure. Here is the solution the other person found. Link to comment Share on other sites More sharing options...
bigjohn 655 Posted January 6, 2015 Share Posted January 6, 2015 Koleckai you've probably already thought of this, but have you tried just completely shutting the firewall off temporarily to see if that is indeed causing the problem? Pretty easy way to eliminate or confirm one possibility. Link to comment Share on other sites More sharing options...
Koleckai Silvestri 1150 Posted January 7, 2015 Author Share Posted January 7, 2015 Same thing happens with or without Windows Firewall on. Not using any third party tools here. Windows Firewall, Windows Defender. All other clients find and connect to the server without problem. I've tested on two different iPhones, a Kindle Fire tablet, two laptops and the local computer (which is probably skewed). Only the Rokus have a problem connecting. Even if the Server is defined in the list, they cannot connect unless the IP Address is type in manually. Link to comment Share on other sites More sharing options...
bigjohn 655 Posted January 7, 2015 Share Posted January 7, 2015 OK, well that at least seems to eliminate the firewall as the cause. Link to comment Share on other sites More sharing options...
Luke 37018 Posted January 7, 2015 Share Posted January 7, 2015 I've updated the zip file. please try it again, and if there's still an issue post a new client log. thanks. Link to comment Share on other sites More sharing options...
Solution Luke 37018 Posted January 7, 2015 Solution Share Posted January 7, 2015 there were certain conditions causing it to skip over testing the local address. so that's been rectified. 1 Link to comment Share on other sites More sharing options...
Luke 37018 Posted January 7, 2015 Share Posted January 7, 2015 As it turns out this update is live in the store now. I just finally heard back from Roku. So both beta and public should be up to 1.78 now Link to comment Share on other sites More sharing options...
Koleckai Silvestri 1150 Posted January 7, 2015 Author Share Posted January 7, 2015 Sorry. Didn't get to the ZIP last night. However upgraded to 1.7.8 this morning and this has solved the issue. Thank you. Link to comment Share on other sites More sharing options...
ginjaninja 533 Posted January 8, 2015 Share Posted January 8, 2015 What is the 1.78 logic / functionality when skipping media browser connect......ill update the help page.. does the roku automatically scan network? Link to comment Share on other sites More sharing options...
