jody 4 Posted November 16, 2014 Share Posted November 16, 2014 Hi all, I was wondering about the plugin for xbmc. So xbmc can use mediabrowser3 as a backend for xbmc, does it offer transcoding on the fly? and how is the media shared between mb3 and xbmc, is it upnp/multicast? I'm searching for a non-upnp/multicast solution that supports transcoding on the fly and can be a media source for xbmc. thx in advance!! Link to comment Share on other sites More sharing options...
Luke 37008 Posted November 16, 2014 Share Posted November 16, 2014 yea try Xbmb3c! 1 Link to comment Share on other sites More sharing options...
jody 4 Posted November 19, 2014 Author Share Posted November 19, 2014 Whichever protocol you set in your mapping of the path files on the media browser server. Mine for example use the NFS protocol which I setup using path substitution on the server. You can also choose to steam via http if you prefer. Try it out and if you have further issues/questions please post them in the Kodi thread http://mediabrowser.tv/community/index.php?/forum/99-kodi/ Thank you, will give it a go Link to comment Share on other sites More sharing options...
jody 4 Posted November 19, 2014 Author Share Posted November 19, 2014 yea try Xbmb3c! thx I will try it, which protocol is it using to share media on the network? Link to comment Share on other sites More sharing options...
Solution im85288 1493 Posted November 19, 2014 Solution Share Posted November 19, 2014 (edited) Whichever protocol you set in your mapping of the path files on the media browser server. Mine for example use the NFS protocol which I setup using path substitution on the server. You can also choose to steam via http if you prefer. Try it out and if you have further issues/questions please post them in the Kodi thread http://mediabrowser.tv/community/index.php?/forum/99-kodi/ Edited November 18, 2014 by im85288 1 Link to comment Share on other sites More sharing options...
