Issue: MBT crashes upon trying to change audio/subtitle (shift+8)
lh1983
 Share
MBT ver: 3.0.5376.18803
Server ver:  3.0.5366.22005
Log file appended to post.
Issue: occurred when trying to watch a subtitled show in MBT. Library is on my NAS, server running on HTPC with link to folder on NAS. Video started fine, but when I went to change the audio stream and put on subtitles (usually accessed by pressing shift+8), the program crashed. It has been rather unstable for the past few days, with lots of "unhandled exceptions" and "insufficient memory" errors.
HTPC specs:
Intel 4960K cooled by Corsair H55
Gigabyte Z97-wifi motherboard
MSI GTX 760 ITX video card
8GB DDR3-PC1333 RAM
System is on SSD; data is on HDD
Any ideas, o wiser ones?
mbt log 9 21.txt
Link to comment
Share on other sites
Is there any more to the log than that?
Does this error reliably happen when you change subtitles, or are you getting these errors elsewhere too? Does it ever crash without having ever started playback?
Link to comment
I will check when I have access to the HTPC again if I can find more to the log.
It reliably happens with some titles; not so with others. My wife reports that she gets "out of memory" errors after about 45 minutes worth of playback. She says that it works again when she reopens MBT, but it will crash again after 30-45 minutes.
When it crashes, it typically crashes within the first few seconds of playback.
Link to comment
  • 2 weeks later...
 Share
