Emby Blog
  • entries
    540
  • comments
    4762
  • views
    3353489
Contributors to this blog
  • Luke 341
  • ebr 68
  • Carlo 31
  • 7illusions 15
  • ScottIsAFool 12
  • Abobader 11
  • xnappo 8
  • radeon 8
  • darwindeeds 7
  • Redshirt 6
  • Cheesegeezer 5
  • sross44 3
  • leedavies 3
  • Aphid 3
  • techywarrior 3
  • bigjohn 3
  • snazy2000 3
  • softworkz 2
  • Soultaker 2
  • chef 2
  • gcw07 2
  • marcelveldt 1
  • hurricanehrndz 1
Emby for Android TV and Fire TV now with Themes and multi-version support
ebr
Themes
The new release of the Android TV and Fire TV apps now have multiple themes you can choose from just like the web app and Theater (Emby Premiere required for theme support).
Multi-version Selection
Now, for movies for which you have multiple versions (in the supported convention) the app will allow you to choose which version to play when playing back from the detail screen.
Other Improvements
Additionally, several improvements have been made to general playback and stability as well as other minor bug fixes including:
  • Improved external subtitle handling
  • Faster seeking
  • Faster dismissal of OSD when resuming
  • Improved playback correction
  • Fix layout problems on non-standard hardware
  • Runaway Playback Prevention (Are you still watching)
  • Like 5
10 Comments
Recommended Comments
NICE!!!!!!!! Now can you guys finally do something about the Live TV missing an art work. That folder icon looks like a hot mess.
Link to comment
Please bring back the one time purchase to unlock live TV streaming! I unlocked this feature on my gen 1 amazon fire TV and I would like to continue to use it on my gen 2 amazon fire TV.
Link to comment
Hi
I found a bug directly in andoid tv, in some movies the controls for, sub,audio and so on, are missing, or not missing but out of screen,
in some movies they are very small, in some movies you don't see them at all, and in some they are large.
this is on a wetek play 2 using android tv 2.4 and emby for android tv (latest version)
Link to comment
I don't seem to be able to directly select a color anymore like I could before this latest update to themes. Did that feature go away when these canned ones were implemented?
Link to comment
Hi.  Yes, the themes replace that feature.  There are themes that just replace the side color like before.
Link to comment
Well, yeah theming... Very important.
But Themes do not matter if the video is freezing because of the server software which seems to get worse every version. Or if you cannot rely on Emby backups because they do not restore everything.
Link to comment
@IQ2000 Not sure if you are running Beta code but I have been on stable release and all of my users have reported perfect performance streaming around the country since around June/July this year.  Many of them are using AFTM or AFTT.
Tried this just recently from my brother's house which is completely on the entire side of the country from me using his poor WiFi and had no issues whatsoever.
If you are having active issues maybe you should try posting about them here with logs so you can get some help.
Link to comment
deanhatescoffee
Are we going to see the refreshed design on Roku any time soon?
Link to comment
If you can report your issue to us we're happy to investigate. thanks !
Link to comment
As I just started using Emby on my Shield, where do I find / enable these themes?
Thanks!
Link to comment
