Emby Blog
  • entries
    555
  • comments
    4908
  • views
    3430796
Contributors to this blog
  • Luke 344
  • ebr 69
  • Carlo 31
  • 7illusions 15
  • sross44 13
  • ScottIsAFool 12
  • Abobader 11
  • radeon 8
  • xnappo 8
  • darwindeeds 7
  • Redshirt 6
  • Cheesegeezer 5
  • leedavies 3
  • Aphid 3
  • bigjohn 3
  • snazy2000 3
  • softworkz 3
  • techywarrior 3
  • Soultaker 2
  • chef 2
  • gcw07 2
  • marcelveldt 1
  • hurricanehrndz 1
Learn how to Create Skins for Emby Theater
By now, you've seen the images of how pretty Emby Theater is:
You can learn more about the app by reading the original announcement:
http://emby.media/community/index.php?/blog/1/entry-290-introducing-the-new-emby-theater-for-windows-and-the-web/
But what about the skinning engine? How can we create our own skins? We're please to announce that it's very easy.
All You Need is a Little HTML
If you can do HTML and JavaScript, then you can build a skin for Emby Theater. It's that easy.
Just Fork the Default Skin
The default skin is open sourced on Github:
https://github.com/MediaBrowser/emby-web-defaultskin
Just fork it, give it a new name, make your changes, and that's all there is to it. You can host your skin directly on Github, and users can easily install it within the app's settings. So fork away and start skinning. We're excited to see what you come up with.
  • Like 9
10 Comments
Recommended Comments
Ben Z
Do you know when this feature will be available for the regular web client?
Luke
We can't offer any dates but the best way to get what you want faster is to help contribute by experimenting with building a skin in Emby Theater, without waiting for the regular web app to have everything you want.
Ben Z
If I get it right, I can't modify elements under "bower_components" folder because it's not in the default skin directory?
knottz
Going to have fun with this.
tmb4016
not going to bother with this now until I see what is happening with some of the UI decisions that are being made regarding custom artwork visibility in some sections. ie TV/Movie Genres
mrfaulk
this looks very cool.... so i have some experience editing/modding skins and phpbb forums but have never "forked" before, as such i'm hoping for a bit of help regarding the instructions.... i downloaded the github package, but where do i place the folder so emby settings recognizes it as a skin? or is there more to it than that? thanks!
mrfaulk
guess it helps reading the instructions carefully, ha ha.... anyway, was able to fork the skin and install it as a plugin, now comes the fun part, doing some editing/modding... the thing is, the plugin lost the user id / settings icon in the top right hand corner, circled in yellow, it's gone, any thoughts? thanks!
mrfaulk
any way to add the github to notepad++ in order to edit/mod on the fly?
mrfaulk
1. any way to add a custom.css file to a fork, which would override other css files, like the web app css tool?
2. any way to refresh app while open so changes will display, rather than having to close and reopen app? keymap?
mrfaulk
not sure what else i can try to get this to work properly.... installing the forked skin plugin from the settings panel works fine, goes smoothly, but as soon as i back out of the settings the search bar and user icon / settings disappear from the top right hand corner as the forked skin is installed, as if i have signed out.... of course when this happens i can no longer use any app settings....
