vxpress 1 Posted November 28, 2015 Share Posted November 28, 2015 I've been running this for awhile with no issues. Then I added several new movies and noticed I wasn't able to "Identify" any of the new titles. It just kind of sits there. Further digging and I see I can't access the application updates, plugin updates (scheduled tasks fail), and can't browse the plugins catalog. Thinking I had an older version I re-downloaded and installed. No issues with install - Version 3.0.5781.3. However I'm still getting issues with viewing the plugin catalog, application updates, and identifying movies. I checked all firewalls (local and network), nothing is blocked, nothing reported in the firewall logs either. I also verified that the computer can access the internet. I can still play movies normally, I can add new movies, etc. I posted the errors from the log below as well as the full logs as an attachment. Any help is much appreciated Chris 2015-11-28 12:50:26.7550 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3Packages.json2015-11-28 12:50:26.7861 Error - App: Error getting response from http://www.mb3admin.com/admin/service/MB3Packages.json *** Error Report *** Version: 3.0.5781.3 Command line: /Applications/Emby.Server.Mac.app/Contents/MacOS/Emby.Server.Mac Operating system: Unix 13.1.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/administrator/.config/mediabrowser-server Mono: 3.10.0 ((detached/d1a1ea3) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe One or more errors occurred System.AggregateException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[system.Net.WebResponse].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () [0x00000] in <filename unknown>:0 InnerException: System.Net.WebException Error getting response stream (ReadDone2): ReceiveFailure at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[system.Net.WebResponse].InnerInvoke (System.Threading.Tasks.TaskCompletionSource`1 tcs, System.Func`2 endMethod, IAsyncResult l) [0x00000] in <filename unknown>:0 InnerException: System.Exception at System.Net.WebConnection.HandleError(WebExceptionStatus st, System.Exception e, System.String where) at System.Net.WebConnection.ReadDone(IAsyncResult result) at System.Net.WebConnection.HandleError (WebExceptionStatus st, System.Exception e, System.String where) [0x00000] in <filename unknown>:0 2015-11-28 12:50:26.7870 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5781.3 Command line: /Applications/Emby.Server.Mac.app/Contents/MacOS/Emby.Server.Mac Operating system: Unix 13.1.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/administrator/.config/mediabrowser-server Mono: 3.10.0 ((detached/d1a1ea3) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe One or more errors occurred MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Common.Net.HttpResponseInfo].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsync>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Common.Net.HttpResponseInfo].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<Get>c__async0.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[system.IO.Stream].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.Updates.InstallationManager+<GetAvailablePackagesWithoutRegistrationInfo>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[system.Collections.Generic.IEnumerable`1[MediaBrowser.Model.Updates.PackageInfo]].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.Updates.InstallationManager+<GetAvailablePluginUpdates>c__async4.MoveNext () [0x00000] in <filename unknown>:0 InnerException: System.AggregateException One or more errors occurred at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[system.Net.WebResponse].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () [0x00000] in <filename unknown>:0 InnerException: System.Net.WebException Error getting response stream (ReadDone2): ReceiveFailure at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[system.Net.WebResponse].InnerInvoke (System.Threading.Tasks.TaskCompletionSource`1 tcs, System.Func`2 endMethod, IAsyncResult l) [0x00000] in <filename unknown>:0 InnerException: System.Exception at System.Net.WebConnection.HandleError(WebExceptionStatus st, System.Exception e, System.String where) at System.Net.WebConnection.ReadDone(IAsyncResult result) at System.Net.WebConnection.HandleError (WebExceptionStatus st, System.Exception e, System.String where) [0x00000] in <filename unknown>:0 2015-11-28 12:50:26.7870 Error - HttpServer: Error processing request for /emby/Packages/Updates?PackageType=UserInstalled *** Error Report *** Version: 3.0.5781.3 Command line: /Applications/Emby.Server.Mac.app/Contents/MacOS/Emby.Server.Mac Operating system: Unix 13.1.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/administrator/.config/mediabrowser-server Mono: 3.10.0 ((detached/d1a1ea3) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe One or more errors occurred ServiceStack.HttpError No Stack Trace Available 2015-11-28 12:50:26.7870 Info - HttpServer: HTTP Response 500 to 192.168.0.59. Time: 45ms. http://192.168.0.15:8096/emby/Packages/Updates?PackageType=UserInstalled2015-11-28 12:50:26.7937 Error - App: Error getting response from http://www.mb3admin.com/admin/service/MB3Packages.json *** Error Report *** Version: 3.0.5781.3 Command line: /Applications/Emby.Server.Mac.app/Contents/MacOS/Emby.Server.Mac Operating system: Unix 13.1.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/administrator/.config/mediabrowser-server Mono: 3.10.0 ((detached/d1a1ea3) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe One or more errors occurred System.AggregateException at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[system.Net.WebResponse].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () [0x00000] in <filename unknown>:0 InnerException: System.Net.WebException Error getting response stream (ReadDone2): ReceiveFailure at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[system.Net.WebResponse].InnerInvoke (System.Threading.Tasks.TaskCompletionSource`1 tcs, System.Func`2 endMethod, IAsyncResult l) [0x00000] in <filename unknown>:0 InnerException: System.Exception at System.Net.WebConnection.HandleError(WebExceptionStatus st, System.Exception e, System.String where) at System.Net.WebConnection.ReadDone(IAsyncResult result) at System.Net.WebConnection.HandleError (WebExceptionStatus st, System.Exception e, System.String where) [0x00000] in <filename unknown>:0 2015-11-28 12:50:26.7944 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5781.3 Command line: /Applications/Emby.Server.Mac.app/Contents/MacOS/Emby.Server.Mac Operating system: Unix 13.1.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/administrator/.config/mediabrowser-server Mono: 3.10.0 ((detached/d1a1ea3) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe One or more errors occurred MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Common.Net.HttpResponseInfo].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsync>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[MediaBrowser.Common.Net.HttpResponseInfo].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<Get>c__async0.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[system.IO.Stream].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.Updates.InstallationManager+<GetAvailablePackagesWithoutRegistrationInfo>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[system.Collections.Generic.IEnumerable`1[MediaBrowser.Model.Updates.PackageInfo]].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.ApplicationHost+<CheckForApplicationUpdate>c__asyncE.MoveNext () [0x00000] in <filename unknown>:0 InnerException: System.AggregateException One or more errors occurred at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[system.Net.WebResponse].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () [0x00000] in <filename unknown>:0 InnerException: System.Net.WebException Error getting response stream (ReadDone2): ReceiveFailure at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[system.Net.WebResponse].InnerInvoke (System.Threading.Tasks.TaskCompletionSource`1 tcs, System.Func`2 endMethod, IAsyncResult l) [0x00000] in <filename unknown>:0 InnerException: System.Exception at System.Net.WebConnection.HandleError(WebExceptionStatus st, System.Exception e, System.String where) at System.Net.WebConnection.ReadDone(IAsyncResult result) at System.Net.WebConnection.HandleError (WebExceptionStatus st, System.Exception e, System.String where) [0x00000] in <filename unknown>:0 2015-11-28 12:50:26.7944 Error - HttpServer: Error processing request for /emby/Packages/Updates?PackageType=System *** Error Report *** Version: 3.0.5781.3 Command line: /Applications/Emby.Server.Mac.app/Contents/MacOS/Emby.Server.Mac Operating system: Unix 13.1.0.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /Users/administrator/.config/mediabrowser-server Mono: 3.10.0 ((detached/d1a1ea3) Application Path: /Applications/Emby.Server.Mac.app/Contents/MonoBundle/Emby.Server.Mac.exe One or more errors occurred ServiceStack.HttpError No Stack Trace Available logs.txt Link to comment Share on other sites More sharing options...
vxpress 1 Posted November 29, 2015 Author Share Posted November 29, 2015 Nevermind, fixed it. My firewall's content filter was blocking it but not logging that it was blocking it. Nice..... 1 Link to comment Share on other sites More sharing options...
Luke 37022 Posted November 29, 2015 Share Posted November 29, 2015 Well done. Link to comment Share on other sites More sharing options...
