Reset LiveTV DRM
Nologic
Nologic
Why:
This was the second time within a month, of having to reset the PlayReady DRM used with WMC LiveTV, do to a hardware upgrade. So being lazy as I am...I wrote a script so I wouldnt' have to hunt down the Web Pages describing the proceedure, then doing everything manually.
Warning:
Don't run this for giggles, any DRM content you have now, may become unusable. So only run this when shit truely has hit the fan.
References:
Microsoft
TheGreenButton
Requirements:
AutoIt
ResetDRM (Silently Downloaded if Not Found)
7-Zip (Silently Download & Installed if No Supported Unarchiver Found)
or
WinRar
How:
The script deletes the old DRM Keys & Cache, and sets you up to create new keys. It does this by deleting the required files, and running CleanDRM, which is a part of ResetDRM, in a manner that works with both Win7 & Win8...and may also work with Vista. To do this it must extract CleanDRM from ResetDRM along with supporting files. This is ideally done by one of your installed Archive apps (WinRar or 7-Zip), but if none are found it will download and silently install 7-Zip.
Instructions:
Install AutoIt and set it to execute scripts when double clicked.
Install one of the Archiver app's listed above.
Now Right Click on desktop and select "New\AutoIt v3 Script" from the context menu, and Rename it "ResetDRM.au3"
Now Right Click "ResetDRM.au3" & select "Edit Script" from the context menu.
Now paste the following code into:
#RequireAdmin
#Include <Array.au3>
Dim $aFiles[3] = ['ADVPACK.DLL' , 'CleanDRM.exe' , 'resetdrm.inf']
For $ii = 0 To UBound( $aFiles ) - 1
	If FileExists( @ScriptDir & '\' & $aFiles[$ii] ) <> 1 Then
		If FileExists( @ScriptDir & '\ResetDRM.exe' ) <> 1 Then InetGet( 'http://go.microsoft.com/fwlink?LinkId=105000' , @ScriptDir & '\ResetDRM.exe' )
			MsgBox( 0 , 'Error:' , 'Failed to Download ResetDRM.exe' )
			Exit
		EndIf
		$s7zip   = _7zip_RegRead()
		$sWinRAR = _WinRAR_RegRead()
		Select
			Case $s7zip <> ''
				RunWait( $s7zip & ' e ResetDRM.exe -aoa' , @ScriptDir , @SW_HIDE )
			Case $sWinRAR <> ''
				RunWait( $sWinRAR & ' e -o+ ResetDRM.exe' , @ScriptDir , @SW_HIDE )
			Case Else
				If _7zip_Fetch() = -1 Then
					MsgBox( 0 , 'Error:' , 'Failed to Download 7-zip' )
					Exit
				Else
				EndIf
		EndSelect
		FileDelete( @ScriptDir & '\ResetDRM.exe' )
		ExitLoop
	EndIf
Next
; Stop Windows Media Center Receiver Service
RunWait( @ComSpec & ' /c net stop ehRecvr' , '' , @SW_HIDE )
; Remove Files
FileDelete( @AppDataCommonDir & '\Microsoft\PlayReady\mspr.hds' )
FileDelete( @AppDataCommonDir & '\Microsoft\eHome\mcendindiv.hds ' )
; Remove Folders
DirRemove( @AppDataCommonDir & '\Microsoft\PlayReady\cache\' , 1 )
DirRemove( @AppDataCommonDir & '\Microsoft\eHome\cache\'     , 1 )
; Copy Files
FileCopy( @ScriptDir & '\ADVPACK.DLL'  , @DesktopDir & '\ResetDRM\ADVPACK.DLL'  , 9 )
FileCopy( @ScriptDir & '\CleanDRM.exe' , @DesktopDir & '\ResetDRM\CleanDRM.exe' , 9 )
FileCopy( @ScriptDir & '\resetdrm.inf' , @DesktopDir & '\ResetDRM\resetdrm.inf' , 9 )
; Execute ResetDRM
RunWait( @ComSpec & ' /c CleanDRM -v' , @DesktopDir & '\ResetDRM\' , @SW_HIDE )
; Remove Files
DirRemove( @DesktopDir & '\ResetDRM\' , 1 )
; Display Message
MsgBox( 0 , 'Finished:' , 'Wait for Update PlayReady to Display' & @LF & 'Then Click "Update" & Finish Wizard.' , 5 )
; Launch WMC in LiveTV Mode
Run( @WindowsDir & '\ehome\ehshell.exe /mcesuperbar://tv?live=true' , '' )
Func _7zip_RegRead()
	$String = RegRead( 'HKLM\SOFTWARE\7-Zip' , 'Path' )
	If $String  = '' Then $String = RegRead( 'HKLM64\SOFTWARE\7-Zip' , 'Path' )
	If $String <> '' Then
		If StringRight( $String , 1 ) <> '\' Then $String &= '\'
		If FileExists( $String & '7z.exe' ) Then
			Return $String & '7z.exe'
		Else
			Return ''
		EndIf
	Else
		Return ''
	EndIf
EndFunc
Func _WinRAR_RegRead()
	$String = RegRead( 'HKLM\SOFTWARE\WinRAR' , 'exe' )
	If $String  = '' Then $String = RegRead( 'HKLM64\SOFTWARE\WinRAR' , 'exe64' )
		$String = StringLeft( $String , StringInStr( $String , '\' , 0 , -1 ))
		If FileExists( $String & 'WinRAR.exe' ) Then
			Return $String & 'WinRAR.exe'
		Else
			Return ''
		EndIf
	Else
		Return ''
	EndIf
EndFunc
Func _7zip_Fetch()
	$sFile = @TempDir & '\' & _RandomString() & '.html'
	InetGet( 'http://www.7-zip.org/index.html' , $sFile )
	$sBuffer = FileRead( $sFile )
	FileDelete( $sFile )
	$RegEx = StringRegExp( $sBuffer , '(?i)<A href="([^"]+?)">Download</A></TD>' , 3 )
	If @OSArch = 'X86' Then
		$iDownload = _DownloadSevenZip( $RegEx , '.exe' , '/S' )
	Else
		$iDownload = _DownloadSevenZip( $RegEx , '.msi' , '/quiet' )
	EndIf
	Return $iDownload
EndFunc
Func _DownloadSevenZip( ByRef $sInput , $sExt , $sSwitch )
	For $ii = 0 To UBound( $sInput ) - 1
		If StringInStr( $sInput[$ii] , $sExt ) > 0 Then
			$sFileName = StringTrimLeft( $sInput[$ii] , StringInStr( $sInput[$ii] , '/' , 0 , -1 ) )
			$iFetch = InetGet( 'http://www.7-zip.org/' & $sInput[$ii] , @ScriptDir & '\' & $sFileName )
			If $iFetch = 0 Then Return -1
			RunWait( @ComSpec & ' /c ' & $sFileName & ' ' & $sSwitch , @ScriptDir , @SW_HIDE )
			FileDelete( @ScriptDir & '\' & $sFileName )
			Return 0
		EndIf
	Next
EndFunc
Func _RandomString()
	$sString = ''
	Dim $aSpace[3]
	For $i = 1 To 15
		$aSpace[0] = Chr( Random( 65 ,  90 , 1 )) ; A-Z
		$aSpace[1] = Chr( Random( 97 , 122 , 1 )) ; a-z
		$aSpace[2] = Chr( Random( 48 ,  57 , 1 )) ; 0-9
		$sString &= $aSpace[Random( 0 , 2 , 1 )]
	Next
	Return $sString
EndFunc
Now save the script & execute it by double clicking it and if all went well...then you should be greeted by WMC launched to LiveTV, given a bit of time you should be prompted to Update PlayReady DRM...Click "Update" and complete the wizard....sorry couldn't figure out a way to automate this. :(
Edited by Nologic
Link to comment
Share on other sites
