Media Center Remote Control Use!
xzavier.omyda
Go to solution Solved by xzavier.omyda,
xzavier.omyda
I was wondering if support for Windows Media Center remote control could be added. I noticed on Plex it works, but on MB it doesn't! I am using the MetroUI apps for both softwares. I am not sure if it works on MB Theater because I cant seem to get it to work at. Thanks!
Link to comment
Share on other sites
  • Solution
xzavier.omyda
Oh, never mind! Setting the app to mouse and keyboard layout fixed it! You guys are the best!
  • Like 1
Link to comment
  • 8 months later...
megamacx
Does this allow you to control Windows Media Center on your HTPC from another device? I have used a server called "Remote Potato" whose web interface allows to play the exact same commands of a remote control, but from the browser.  Thoughts?
Link to comment
